주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Humax RM-H01U Remote Disassembly
필요한 것
    1. Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: 1 단계, 이미지 2개 중 1개 Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: 1 단계, 이미지 2개 중 2개
      • The remote has a bottom and top part. They are held together with plastic clips.
      • Don't forget to remove the battery, just for good measure.
      댓글 쓰기
    2. Humax RM-H01U Remote Disassembly, Opening using a spudger: 2 단계, 이미지 3개 중 1개 Humax RM-H01U Remote Disassembly, Opening using a spudger: 2 단계, 이미지 3개 중 2개 Humax RM-H01U Remote Disassembly, Opening using a spudger: 2 단계, 이미지 3개 중 3개
      • Use a spudger, prying tool or a flatbed screwdriver to pry open the two halves. Start at the center.
      • The two halves are clamped together firmly.
      • Work your way to the front, and then back again on the other side.
      • See the next step for the location of the clips.
      댓글 쓰기
    3. Humax RM-H01U Remote Disassembly, Clip locations: 3 단계, 이미지 1개 중 1개
      • The clips are located 3 centimeters apart. The first clip is 1 centimeter from the front of the remote.
      • The hooks of the clips are on the bottom halve of the remote and face inward.
      • The top halve of the remote has indents where the clips grab into.
      댓글 쓰기
    4. Humax RM-H01U Remote Disassembly, All parts of the remote: 4 단계, 이미지 1개 중 1개
      • These are all the parts.
      • I cleaned all parts with a toothbrush first.
      • Then I cleaned the PCB and the back of the silicone buttons with pure alcohol.
      • Make sure not to brush too hard! You might remove the carbon layer that is applied. (It's the carbon layer that makes the electrical connection, so it's essential).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jurrie
회원 가입일: 05/07/21
763 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 38
전체 시간: 832
