주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HyperX QuadCast S Mute Sensor Replacement
  1. HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: 1 단계, 이미지 3개 중 1개 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: 1 단계, 이미지 3개 중 2개 HyperX QuadCast S Mute Sensor Replacement, Tap-To-Mute Sensor: 1 단계, 이미지 3개 중 3개
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
    댓글 쓰기
  2. HyperX QuadCast S Mute Sensor Replacement: 2 단계, 이미지 3개 중 1개 HyperX QuadCast S Mute Sensor Replacement: 2 단계, 이미지 3개 중 2개 HyperX QuadCast S Mute Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
    • Be careful not to damage the cable as you remove the top.
    • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
    댓글 쓰기
  3. HyperX QuadCast S Mute Sensor Replacement: 3 단계, 이미지 3개 중 1개 HyperX QuadCast S Mute Sensor Replacement: 3 단계, 이미지 3개 중 2개 HyperX QuadCast S Mute Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
    • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nathan Arruda
회원 가입일: 10/25/22
765 평판
안내서 6개를 작성함
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G1
5 회원들
안내서 15개를 작성함
4가이드 댓글
Nice guide, but I've been unable to find a replacement.
Is the tap sensor from the Quadcast (the non-S version) compatible?
P S - 답글 공유
I believe it should be compatible. The S version should just be different with its illumination and USB charging so the tap-to-mute sensor should be the same. Unfortunately, it's hard to source replacement parts since hyperx does not sell them separately. I could only recommend buying a used hyperx microphone for cheap and scraping the parts for replacement. Hope that helps.
Nathan Arruda - 답글 공유
what is the cable order to put them back in. i have a yellow, red, white, and black cable
Jeremy Ray - 답글 공유
Donde puedo comprar una remplazo de la Quadcast S TOUCH BOARD.V1 w45/19.hz?
Eladio Valencia Meneses - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 109
전체 시간: 5,684
