주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HyperX QuadCast S Pop Filter Replacement
    1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: 1 단계, 이미지 3개 중 1개 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: 1 단계, 이미지 3개 중 2개 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: 1 단계, 이미지 3개 중 3개
      • Set the microphone on a flat surface.
      • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
      • There are four support bands in total, but it does not matter which band you choose to take off first.
      댓글 쓰기
    2. HyperX QuadCast S Pop Filter Replacement: 2 단계, 이미지 3개 중 1개 HyperX QuadCast S Pop Filter Replacement: 2 단계, 이미지 3개 중 2개 HyperX QuadCast S Pop Filter Replacement: 2 단계, 이미지 3개 중 3개
      • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
      • Be careful not to damage the cable as you remove the top.
      • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
      댓글 쓰기
    3. HyperX QuadCast S Pop Filter Replacement: 3 단계, 이미지 3개 중 1개 HyperX QuadCast S Pop Filter Replacement: 3 단계, 이미지 3개 중 2개 HyperX QuadCast S Pop Filter Replacement: 3 단계, 이미지 3개 중 3개
      • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
      • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
      댓글 쓰기
    1. HyperX QuadCast S Pop Filter Replacement, Pop Filter: 4 단계, 이미지 1개 중 1개
      • Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
      • The pop filter is just the grey foam surrounding the inside of the microphone.
      댓글 쓰기
    2. HyperX QuadCast S Pop Filter Replacement: 5 단계, 이미지 1개 중 1개
      • The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
      • When you replace the pop filter, remember that you will need to glue it back into place as before.
      댓글 쓰기
    3. HyperX QuadCast S Pop Filter Replacement: 6 단계, 이미지 2개 중 1개 HyperX QuadCast S Pop Filter Replacement: 6 단계, 이미지 2개 중 2개
      • Reach into the microphone and remove the pop filter.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nathan Arruda
회원 가입일: 10/25/22
765 평판
안내서 6개를 작성함
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G1
5 회원들
안내서 15개를 작성함
3가이드 댓글
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
Kyle Villalovos - 답글 공유
Is there a place where you recomend i can get a replacement peice of foam for the pop filter. I cant find one anywhere online.
Liam Henesy - 답글 공유
did you happen to find anything?
Kamen C-Swartz - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 38
지난 30일: 110
전체 시간: 4,518
