주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IBM ThinkPad T30 Keyboard Replacement
필요한 것
    1. IBM ThinkPad T30 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 IBM ThinkPad T30 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 IBM ThinkPad T30 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      댓글 쓰기
    1. IBM ThinkPad T30 Keyboard Replacement, Keyboard: 2 단계, 이미지 2개 중 1개 IBM ThinkPad T30 Keyboard Replacement, Keyboard: 2 단계, 이미지 2개 중 2개
      • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
      • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
      • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
      댓글 쓰기
    2. IBM ThinkPad T30 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 IBM ThinkPad T30 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 IBM ThinkPad T30 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
      • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
      • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
      • Use the plastic opening tool to gently pry the connector up from the motherboard.
      • You can now safely remove the keyboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Alex Kost
회원 가입일: 10/05/12
271 평판
안내서 5개를 작성함
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G20
3 회원들
안내서 96개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 47
전체 시간: 3,747
