주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IBM ThinkPad T41 Modem Replacement
필요한 것
  1. IBM ThinkPad T41 Modem Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    댓글 쓰기
  2. IBM ThinkPad T41 Modem Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    댓글 쓰기
  3. IBM ThinkPad T41 Modem Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    댓글 쓰기
  4. IBM ThinkPad T41 Modem Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    댓글 쓰기
  5. IBM ThinkPad T41 Modem Replacement, Modem: 5 단계, 이미지 1개 중 1개
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
    댓글 쓰기
  6. IBM ThinkPad T41 Modem Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the modem up, unplugging it from the motherboard as you lift.
    댓글 쓰기
  7. IBM ThinkPad T41 Modem Replacement: 7 단계, 이미지 2개 중 1개 IBM ThinkPad T41 Modem Replacement: 7 단계, 이미지 2개 중 2개
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Marissa Blustein
회원 가입일: 04/16/10
543 평판
안내서 12개를 작성함
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 회원
CPSU-MANESS-S10S7G8
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 40
전체 시간: 4,672
