주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IBM ThinkPad T42 Display Replacement
필요한 것
  1. IBM ThinkPad T42 Display Replacement, Bottom cover: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
    댓글 쓰기
  2. IBM ThinkPad T42 Display Replacement, Rear screws: 2 단계, 이미지 1개 중 1개
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
    댓글 쓰기
  3. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: 3 단계, 이미지 1개 중 1개
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
    댓글 쓰기
  4. IBM ThinkPad T42 Display Replacement: 4 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Display Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    댓글 쓰기
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: 5 단계, 이미지 2개 중 1개 IBM ThinkPad T42 Display Replacement, Bezel Removal: 5 단계, 이미지 2개 중 2개
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
    댓글 쓰기
  6. IBM ThinkPad T42 Display Replacement, Display Screws: 6 단계, 이미지 1개 중 1개
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
    댓글 쓰기
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: 7 단계, 이미지 1개 중 1개
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Austin Kidd
회원 가입일: 04/21/10
317 평판
안내서 3개를 작성함
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 37개를 작성함
2가이드 댓글
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - 답글 공유
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 50
전체 시간: 13,989
