주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IBM Thinkpad T60 LCD Screen Replacement
필요한 것
  1. IBM Thinkpad T60 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    댓글 쓰기
  2. IBM Thinkpad T60 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 IBM Thinkpad T60 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    댓글 쓰기
  3. IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 1개 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 2개 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 3개
    • Open the laptop so that the screen is facing you.
    • Use a plastic opening tool to pry off the eight plastic screw covers around the display.
    • Note that there are screw covers on the sides (two on the left and one on the right).
    댓글 쓰기
  4. IBM Thinkpad T60 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Use a #0 Phillips screwdriver to remove the eight 3.25 mm screws uncapped from the previous step.
    댓글 쓰기
  5. IBM Thinkpad T60 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 IBM Thinkpad T60 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully pry the plastic border away from the screen using the plastic opening tool.
    • Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
    댓글 쓰기
  6. IBM Thinkpad T60 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use your fingers to pry the screen out of its housing far enough to gain access to the ribbon cables and small screws holding the screen in place.
    댓글 쓰기
  7. IBM Thinkpad T60 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • At the top of the screen, detach the small white clip by pulling it towards you with your finger.
    댓글 쓰기
  8. IBM Thinkpad T60 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 IBM Thinkpad T60 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Using a #0 Phillips screwdriver, remove the 4 mm screw.
    댓글 쓰기
  9. IBM Thinkpad T60 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 IBM Thinkpad T60 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
    • The other two screws are in the same position on the opposite side of the display.
    댓글 쓰기
  10. IBM Thinkpad T60 LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 IBM Thinkpad T60 LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • The screen should be free to move now. Let the display rest on the keyboard with the screen facing down.
    • Peel the tape off to expose the LCD connection.
    댓글 쓰기
  11. IBM Thinkpad T60 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 IBM Thinkpad T60 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Turn the inverter over to expose the white clip.
    • Squeeze and pull the wires with your fingers to detach the white clip.
    댓글 쓰기
  12. IBM Thinkpad T60 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Disconnect the video cable by pulling the grey flat wire. Now the screen is completely separate from the ThinkPad.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Cody Kratochvil
회원 가입일: 01/11/13
581 평판
안내서 5개를 작성함
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 회원
CPSU-MANESS-W13S7G9
4 회원들
안내서 16개를 작성함
1가이드 댓글
Thanks for the info! ☼
Stck Flw - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 66
전체 시간: 13,814
