주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
IBM Thinkpad T60 Wireless Card Replacement
필요한 것
  1. IBM Thinkpad T60 Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    댓글 쓰기
  2. IBM Thinkpad T60 Wireless Card Replacement: 2 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement: 2 단계, 이미지 2개 중 2개
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    댓글 쓰기
  3. IBM Thinkpad T60 Wireless Card Replacement, Palm Rest: 3 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement, Palm Rest: 3 단계, 이미지 2개 중 2개
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    댓글 쓰기
  4. IBM Thinkpad T60 Wireless Card Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
    댓글 쓰기
  5. IBM Thinkpad T60 Wireless Card Replacement: 5 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement: 5 단계, 이미지 2개 중 2개
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
    • Detach the connector by pulling upwards on the white tab.
    댓글 쓰기
  6. IBM Thinkpad T60 Wireless Card Replacement, Keyboard: 6 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement, Keyboard: 6 단계, 이미지 2개 중 2개
    • Turn the Thinkpad over so you can see the bottom.
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
    댓글 쓰기
  7. IBM Thinkpad T60 Wireless Card Replacement: 7 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement: 7 단계, 이미지 2개 중 2개
    • First, flip the laptop back over. Next, use your fingers to pry the keyboard upwards slightly.
    • Lift the keyboard until you are able to see the wire connection
    댓글 쓰기
  8. IBM Thinkpad T60 Wireless Card Replacement: 8 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement: 8 단계, 이미지 2개 중 2개
    • Pull upwards on the connector to disconnect the keyboard.
    • The keyboard is now disconnected.
    댓글 쓰기
  9. IBM Thinkpad T60 Wireless Card Replacement, Wireless Card: 9 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement, Wireless Card: 9 단계, 이미지 2개 중 2개
    • Using a #0 Phillips screwdriver, remove the two 10.5 mm screws.
    댓글 쓰기
  10. IBM Thinkpad T60 Wireless Card Replacement: 10 단계, 이미지 2개 중 1개 IBM Thinkpad T60 Wireless Card Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the two connectors by pulling upwards on the base of the grey and black cables.
    댓글 쓰기
  11. IBM Thinkpad T60 Wireless Card Replacement: 11 단계, 이미지 1개 중 1개
    • Grasp the sides of the card and pull perpendicular to the slot.
    • The wireless card is now disconnected.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Cody Kratochvil
회원 가입일: 01/11/13
581 평판
안내서 5개를 작성함
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 회원
CPSU-MANESS-W13S7G9
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 57
전체 시간: 6,797
