주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ILVE Microwave Replacement Bulb Replacement
필요한 것
    1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: 1 단계, 이미지 1개 중 1개
      • Remove the brown plug.
      • The screw attaching the microwave is below
      댓글 쓰기
    2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: 2 단계, 이미지 2개 중 1개 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: 2 단계, 이미지 2개 중 2개
      • Remove the cross point screws from the outer case back
      • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
      • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
      댓글 쓰기
    3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: 3 단계, 이미지 1개 중 1개
      • The socket is on top right side of the microwave
      • Remove the plugs
      • Bend up the metal clips, and pull out the socket
      댓글 쓰기
    4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: 4 단계, 이미지 2개 중 1개 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: 4 단계, 이미지 2개 중 2개
      • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
      • The glue goes all the way down the thread so remove as much as you can see.
      • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
      댓글 쓰기
    5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: 5 단계, 이미지 1개 중 1개
      • When you re assemble the outer case make sure the tabs on the front go either side of the front.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Martin Hampton
회원 가입일: 02/13/16
1,350 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 61
전체 시간: 4,476
