주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus IN3104 Color Wheel Replacement
필요한 것
    1. InFocus IN3104 Color Wheel Replacement, Top Cover: 1 단계, 이미지 3개 중 1개 InFocus IN3104 Color Wheel Replacement, Top Cover: 1 단계, 이미지 3개 중 2개 InFocus IN3104 Color Wheel Replacement, Top Cover: 1 단계, 이미지 3개 중 3개
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      댓글 쓰기
    2. InFocus IN3104 Color Wheel Replacement: 2 단계, 이미지 3개 중 1개 InFocus IN3104 Color Wheel Replacement: 2 단계, 이미지 3개 중 2개 InFocus IN3104 Color Wheel Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      댓글 쓰기
    1. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 2개 중 1개 InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
      • Lift up the metal cover and set it aside to reveal the motherboard.
      댓글 쓰기
    2. InFocus IN3104 Color Wheel Replacement: 4 단계, 이미지 3개 중 1개 InFocus IN3104 Color Wheel Replacement: 4 단계, 이미지 3개 중 2개 InFocus IN3104 Color Wheel Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
      • Pull out the blue-tipped, white ribbon cable from the connector.
      • Remove the metal cover.
      댓글 쓰기
    1. InFocus IN3104 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 3개 중 1개 InFocus IN3104 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 3개 중 2개 InFocus IN3104 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 3개 중 3개
      • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
      댓글 쓰기
    2. InFocus IN3104 Color Wheel Replacement: 6 단계, 이미지 2개 중 1개 InFocus IN3104 Color Wheel Replacement: 6 단계, 이미지 2개 중 2개
      • Carefully lift up the black paper cover. Do not completely remove it from the device.
      • Lift the paper cover up to reveal two 6mm screws.
      댓글 쓰기
    3. InFocus IN3104 Color Wheel Replacement: 7 단계, 이미지 2개 중 1개 InFocus IN3104 Color Wheel Replacement: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the two 6mm screws.
      • Remove the color wheel from the device by lifting it out of the projector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 44
전체 시간: 865
