주요 콘텐츠로 건너뛰기
InFocus IN3104 Color Wheel Replacement
필요한 것
  1. InFocus IN3104 Color Wheel Replacement, Top Cover: 1 단계, 이미지 1/3 InFocus IN3104 Color Wheel Replacement, Top Cover: 1 단계, 이미지 2/3 InFocus IN3104 Color Wheel Replacement, Top Cover: 1 단계, 이미지 3/3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Color Wheel Replacement: 2 단계, 이미지 1/3 InFocus IN3104 Color Wheel Replacement: 2 단계, 이미지 2/3 InFocus IN3104 Color Wheel Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 1/2 InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Color Wheel Replacement: 4 단계, 이미지 1/3 InFocus IN3104 Color Wheel Replacement: 4 단계, 이미지 2/3 InFocus IN3104 Color Wheel Replacement: 4 단계, 이미지 3/3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 1/3 InFocus IN3104 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 2/3 InFocus IN3104 Color Wheel Replacement, Color Wheel: 5 단계, 이미지 3/3
    • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
  6. InFocus IN3104 Color Wheel Replacement: 6 단계, 이미지 1/2 InFocus IN3104 Color Wheel Replacement: 6 단계, 이미지 2/2
    • Carefully lift up the black paper cover. Do not completely remove it from the device.
    • Lift the paper cover up to reveal two 6mm screws.
  7. InFocus IN3104 Color Wheel Replacement: 7 단계, 이미지 1/2 InFocus IN3104 Color Wheel Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the two 6mm screws.
    • Remove the color wheel from the device by lifting it out of the projector.
결론
Christopher Held
회원 가입일: 01/26/20
181 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 293
