주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus IN3104 Cooling Fan Replacement
필요한 것
    1. InFocus IN3104 Cooling Fan Replacement, Top Cover: 1 단계, 이미지 3개 중 1개 InFocus IN3104 Cooling Fan Replacement, Top Cover: 1 단계, 이미지 3개 중 2개 InFocus IN3104 Cooling Fan Replacement, Top Cover: 1 단계, 이미지 3개 중 3개
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      댓글 쓰기
    2. InFocus IN3104 Cooling Fan Replacement: 2 단계, 이미지 3개 중 1개 InFocus IN3104 Cooling Fan Replacement: 2 단계, 이미지 3개 중 2개 InFocus IN3104 Cooling Fan Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      댓글 쓰기
    1. InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 2개 중 1개 InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
      • Lift up the metal cover and set it aside to reveal the motherboard.
      댓글 쓰기
    2. InFocus IN3104 Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 InFocus IN3104 Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 InFocus IN3104 Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
      • Pull out the blue-tipped, white ribbon cable from the connector.
      • Remove the metal cover.
      댓글 쓰기
    1. InFocus IN3104 Cooling Fan Replacement, Cooling Fan: 5 단계, 이미지 2개 중 1개 InFocus IN3104 Cooling Fan Replacement, Cooling Fan: 5 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
      • The screws are in a tight location, so you may need a thin screwdriver or an extension to remove them.
      댓글 쓰기
    2. InFocus IN3104 Cooling Fan Replacement: 6 단계, 이미지 3개 중 1개 InFocus IN3104 Cooling Fan Replacement: 6 단계, 이미지 3개 중 2개 InFocus IN3104 Cooling Fan Replacement: 6 단계, 이미지 3개 중 3개
      • Unplug the yellow, red, and black colored cable bundle from the motherboard.
      • Remove the cooling fan from the device by lifting it out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Tae Min Kim
회원 가입일: 01/24/20
409 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 30
전체 시간: 887
