주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus LP435Z DLP Board Replacement
필요한 것
    1. InFocus LP435Z DLP Board Replacement, External Shell: 1 단계, 이미지 2개 중 1개 InFocus LP435Z DLP Board Replacement, External Shell: 1 단계, 이미지 2개 중 2개
      • Place the projector on its back (buttons down) with the lens facing away from you.
      • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
      • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
      댓글 쓰기
    2. InFocus LP435Z DLP Board Replacement: 2 단계, 이미지 2개 중 1개 InFocus LP435Z DLP Board Replacement: 2 단계, 이미지 2개 중 2개
      • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
      • There is no lamp assembly in the projector used in this guide, yours may appear different.
      댓글 쓰기
    3. InFocus LP435Z DLP Board Replacement: 3 단계, 이미지 2개 중 1개 InFocus LP435Z DLP Board Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
      • Pull the rear plate straight off and set it aside.
      댓글 쓰기
    4. InFocus LP435Z DLP Board Replacement: 4 단계, 이미지 3개 중 1개 InFocus LP435Z DLP Board Replacement: 4 단계, 이미지 3개 중 2개 InFocus LP435Z DLP Board Replacement: 4 단계, 이미지 3개 중 3개
      • Flip the projector over and turn around so that the lens faces you.
      • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
      • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
      • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
      댓글 쓰기
    5. InFocus LP435Z DLP Board Replacement: 5 단계, 이미지 2개 중 1개 InFocus LP435Z DLP Board Replacement: 5 단계, 이미지 2개 중 2개
      • Lift away the top case plate and set it aside.
      댓글 쓰기
    1. InFocus LP435Z DLP Board Replacement, DLP Board: 6 단계, 이미지 1개 중 1개
      • Remove the four T10 Torx 8.5 mm screws holding the DLP board in place.
      댓글 쓰기
    2. InFocus LP435Z DLP Board Replacement: 7 단계, 이미지 1개 중 1개
      • Unplug the small ribbon cable attaching the DLP board to the motherboard.
      댓글 쓰기
    3. InFocus LP435Z DLP Board Replacement: 8 단계, 이미지 2개 중 1개 InFocus LP435Z DLP Board Replacement: 8 단계, 이미지 2개 중 2개
      • Detach the DLP board from where it is connected to the motherboard by a large 100 pin connector.
      • Pry up gently while wiggling from left to right if needed.
      • The ribbon cable on the other side of the board could break if pulled too hard.
      댓글 쓰기
    4. InFocus LP435Z DLP Board Replacement: 9 단계, 이미지 2개 중 1개 InFocus LP435Z DLP Board Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the black plastic retaining clip reinforcing the large ribbon cable connector by prying it from the left edge.
      • Gently pry the large ribbon cable connector from the DLP board, and remove the board.
      • Using too much force could damage the connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Andrew Kennedy
회원 가입일: 01/29/13
186 평판
안내서 6개를 작성함
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013 회원
CPSU-MANESS-W13S20G3
4 회원들
안내서 31개를 작성함
1가이드 댓글
I Andrew
Recently I bought an INFOCUS LP435Z, it was with the inverted image, when I wanted to use the buttons to enter the menu, to modify the image inversion, none of the buttons reacted.
You will have an idea of what is due and how to solve it? Could it be that with the option of active blocking? I do not have the unlock key, how could I check it?
Thank you very much for your answer.
Regards
Maximiliano - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 23
전체 시간: 2,638
