주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus LP435Z Main Fan Replacement
필요한 것
    1. InFocus LP435Z Main Fan Replacement, External Shell: 1 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement, External Shell: 1 단계, 이미지 2개 중 2개
      • Place the projector on its back (buttons down) with the lens facing away from you.
      • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
      • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
      댓글 쓰기
    2. InFocus LP435Z Main Fan Replacement: 2 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 2 단계, 이미지 2개 중 2개
      • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
      • There is no lamp assembly in the projector used in this guide, yours may appear different.
      댓글 쓰기
    3. InFocus LP435Z Main Fan Replacement: 3 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
      • Pull the rear plate straight off and set it aside.
      댓글 쓰기
    4. InFocus LP435Z Main Fan Replacement: 4 단계, 이미지 3개 중 1개 InFocus LP435Z Main Fan Replacement: 4 단계, 이미지 3개 중 2개 InFocus LP435Z Main Fan Replacement: 4 단계, 이미지 3개 중 3개
      • Flip the projector over and turn around so that the lens faces you.
      • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
      • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
      • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
      댓글 쓰기
    5. InFocus LP435Z Main Fan Replacement: 5 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 5 단계, 이미지 2개 중 2개
      • Lift away the top case plate and set it aside.
      댓글 쓰기
    1. InFocus LP435Z Main Fan Replacement, Main Fan: 6 단계, 이미지 1개 중 1개
      • Remove the four T10 Torx 8.5 mm screws holding the DLP board in place.
      댓글 쓰기
    2. InFocus LP435Z Main Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Unplug the small ribbon cable attaching the DLP board to the motherboard.
      댓글 쓰기
    3. InFocus LP435Z Main Fan Replacement: 8 단계, 이미지 1개 중 1개
      • Remove Secondary Fan Cable
      댓글 쓰기
    4. InFocus LP435Z Main Fan Replacement: 9 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 9 단계, 이미지 2개 중 2개
      • Detach the DLP board from where it is connected to the motherboard by a large 100 pin connector.
      • Pry up gently while wiggling from left to right if needed.
      • The ribbon cable on the other side of the board could break if pulled too hard.
      댓글 쓰기
    5. InFocus LP435Z Main Fan Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the 2 remaining T10 Torx 8mm screws securing the motherboard to the power supply.
      댓글 쓰기
    6. InFocus LP435Z Main Fan Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the speaker power cable.
      댓글 쓰기
    7. InFocus LP435Z Main Fan Replacement: 12 단계, 이미지 1개 중 1개
      • Remove DLP Power Cable.
      댓글 쓰기
    8. InFocus LP435Z Main Fan Replacement: 13 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 13 단계, 이미지 2개 중 2개
      • Pry out the DLP support piece by gently wiggling it side to side while applying a steady pull. It will slide out.
      댓글 쓰기
    9. InFocus LP435Z Main Fan Replacement: 14 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the black plastic retaining clip reinforcing the large ribbon cable connector by prying it from the left edge.
      • Gently pry the large ribbon cable connector from the DLP board, and remove the board.
      • Using too much force could damage the connector.
      댓글 쓰기
    10. InFocus LP435Z Main Fan Replacement: 15 단계, 이미지 3개 중 1개 InFocus LP435Z Main Fan Replacement: 15 단계, 이미지 3개 중 2개 InFocus LP435Z Main Fan Replacement: 15 단계, 이미지 3개 중 3개
      • Remove the two 1/4" screws using the nut driver.
      • The second screw is located behind the right side of the 100 pin connector.
      • Gently pry up the motherboard from the connector on top of the power supply.
      댓글 쓰기
    11. InFocus LP435Z Main Fan Replacement: 16 단계, 이미지 2개 중 1개 InFocus LP435Z Main Fan Replacement: 16 단계, 이미지 2개 중 2개
      • Disconnect the lamp power supply cables from the top of the lamp housing, by gently pulling the two wires in opposite directions.
      댓글 쓰기
    12. InFocus LP435Z Main Fan Replacement: 17 단계, 이미지 3개 중 1개 InFocus LP435Z Main Fan Replacement: 17 단계, 이미지 3개 중 2개 InFocus LP435Z Main Fan Replacement: 17 단계, 이미지 3개 중 3개
      • Use your thumbs to pry the sides of the external shell away from the power supply so it can be lifted out.
      댓글 쓰기
    13. InFocus LP435Z Main Fan Replacement: 18 단계, 이미지 1개 중 1개
      • Detach the main fan power cable from the power supply.
      댓글 쓰기
    14. InFocus LP435Z Main Fan Replacement: 19 단계, 이미지 3개 중 1개 InFocus LP435Z Main Fan Replacement: 19 단계, 이미지 3개 중 2개 InFocus LP435Z Main Fan Replacement: 19 단계, 이미지 3개 중 3개
      • Use the needle nose pliers to pull out the grommets securing the main fan to its housing.
      • To replace grommets, pull the center pins from their housing, and slip the exteriors of the grommets back into their holes in the fan housing, then push the centers in to secure them in place.
      댓글 쓰기
    15. InFocus LP435Z Main Fan Replacement: 20 단계, 이미지 1개 중 1개
      • Remove the fan from its housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Andrew Kennedy
회원 가입일: 01/29/13
186 평판
안내서 6개를 작성함
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013 회원
CPSU-MANESS-W13S20G3
4 회원들
안내서 37개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 2,794
