주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus LP435Z Power Supply Replacement
필요한 것
    1. InFocus LP435Z Power Supply Replacement, External Shell: 1 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement, External Shell: 1 단계, 이미지 2개 중 2개
      • Place the projector on its back (buttons down) with the lens facing away from you.
      • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
      • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
      댓글 쓰기
    2. InFocus LP435Z Power Supply Replacement: 2 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 2 단계, 이미지 2개 중 2개
      • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
      • There is no lamp assembly in the projector used in this guide, yours may appear different.
      댓글 쓰기
    3. InFocus LP435Z Power Supply Replacement: 3 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
      • Pull the rear plate straight off and set it aside.
      댓글 쓰기
    4. InFocus LP435Z Power Supply Replacement: 4 단계, 이미지 3개 중 1개 InFocus LP435Z Power Supply Replacement: 4 단계, 이미지 3개 중 2개 InFocus LP435Z Power Supply Replacement: 4 단계, 이미지 3개 중 3개
      • Flip the projector over and turn around so that the lens faces you.
      • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
      • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
      • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
      댓글 쓰기
    5. InFocus LP435Z Power Supply Replacement: 5 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 5 단계, 이미지 2개 중 2개
      • Lift away the top case plate and set it aside.
      댓글 쓰기
    1. InFocus LP435Z Power Supply Replacement, Power Supply: 6 단계, 이미지 1개 중 1개
      • Remove the four T10 Torx 8.5 mm screws holding the DLP board in place.
      댓글 쓰기
    2. InFocus LP435Z Power Supply Replacement: 7 단계, 이미지 1개 중 1개
      • Unplug the small ribbon cable attaching the DLP board to the motherboard.
      댓글 쓰기
    3. InFocus LP435Z Power Supply Replacement: 8 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 8 단계, 이미지 2개 중 2개
      • Detach the DLP board from where it is connected to the motherboard by a large 100 pin connector.
      • Pry up gently while wiggling from left to right if needed.
      • The ribbon cable on the other side of the board could break if pulled too hard.
      댓글 쓰기
    4. InFocus LP435Z Power Supply Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the 2 remaining T10 Torx 8mm screws securing the motherboard to the power supply.
      댓글 쓰기
    5. InFocus LP435Z Power Supply Replacement: 10 단계, 이미지 1개 중 1개
      • Remove all other cables connected to the motherboard.
      • Remove the Speaker Cable
      댓글 쓰기
    6. InFocus LP435Z Power Supply Replacement: 11 단계, 이미지 1개 중 1개
      • Remove Secondary Fan Cable
      댓글 쓰기
    7. InFocus LP435Z Power Supply Replacement: 12 단계, 이미지 1개 중 1개
      • Flip up the DLP board, leaving it attached to the large ribbon cable.
      • Remove DLP Power Cable.
      댓글 쓰기
    8. InFocus LP435Z Power Supply Replacement: 13 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 13 단계, 이미지 2개 중 2개
      • Pry out the DLP support piece by gently wiggling it side to side while applying a steady pull. It will slide out.
      댓글 쓰기
    9. InFocus LP435Z Power Supply Replacement: 14 단계, 이미지 3개 중 1개 InFocus LP435Z Power Supply Replacement: 14 단계, 이미지 3개 중 2개 InFocus LP435Z Power Supply Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the two 1/4" screws using the nut driver.
      • The second screw is located behind the right side of the 100 pin connector.
      • Gently pry up the motherboard from the connector on top of the power supply.
      댓글 쓰기
    10. InFocus LP435Z Power Supply Replacement: 15 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 15 단계, 이미지 2개 중 2개
      • Disconnect the lamp power supply cables from the top of the lamp housing, by gently pulling the two wires in opposite directions.
      댓글 쓰기
    11. InFocus LP435Z Power Supply Replacement: 16 단계, 이미지 3개 중 1개 InFocus LP435Z Power Supply Replacement: 16 단계, 이미지 3개 중 2개 InFocus LP435Z Power Supply Replacement: 16 단계, 이미지 3개 중 3개
      • Use your thumbs to pry the sides of the external shell away from the power supply so it can be lifted out.
      댓글 쓰기
    12. InFocus LP435Z Power Supply Replacement: 17 단계, 이미지 3개 중 1개 InFocus LP435Z Power Supply Replacement: 17 단계, 이미지 3개 중 2개 InFocus LP435Z Power Supply Replacement: 17 단계, 이미지 3개 중 3개
      • Rotate the power supply so that the main fan enclosure faces to the right, with the motherboard mounting pegs on top.
      • Remove the two #2 Phillips 7mm screws on the side of the power supply.
      • Remove two more #2 Phillips 7mm screws on the opposite side of the power supply.
      • Rotate the power supply so the fan faces towards you, and remove a fifth #2 Phillips 7mm screw from just under the foam pad.
      댓글 쓰기
    13. InFocus LP435Z Power Supply Replacement: 18 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 18 단계, 이미지 2개 중 2개
      • Use a plastic prying tool to push the white molex connector through the fan enclosure.
      댓글 쓰기
    14. InFocus LP435Z Power Supply Replacement: 19 단계, 이미지 2개 중 1개 InFocus LP435Z Power Supply Replacement: 19 단계, 이미지 2개 중 2개
      • Flip the power supply over so that the motherboard mounting pegs are on the bottom.
      • Carefully open the power supply, and be mindful of the cable that will be pulled taut that needs to be disconnected.
      • It may be easier to disconnect this cable if you orient the power supply with the speaker down, so you can reach in more easily.
      댓글 쓰기
    15. InFocus LP435Z Power Supply Replacement: 20 단계, 이미지 1개 중 1개
      • The base of the power supply should now be free.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Andrew Kennedy
회원 가입일: 01/29/13
186 평판
안내서 6개를 작성함
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013 회원
CPSU-MANESS-W13S20G3
4 회원들
안내서 31개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 39
전체 시간: 3,229
