주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus LP540 Projector Main Board Replacement
필요한 것
    1. InFocus LP540 Projector Main Board Replacement, Main Board: 1 단계, 이미지 3개 중 1개 InFocus LP540 Projector Main Board Replacement, Main Board: 1 단계, 이미지 3개 중 2개 InFocus LP540 Projector Main Board Replacement, Main Board: 1 단계, 이미지 3개 중 3개
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      댓글 쓰기
    2. InFocus LP540 Projector Main Board Replacement: 2 단계, 이미지 2개 중 1개 InFocus LP540 Projector Main Board Replacement: 2 단계, 이미지 2개 중 2개
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      댓글 쓰기
    3. InFocus LP540 Projector Main Board Replacement: 3 단계, 이미지 3개 중 1개 InFocus LP540 Projector Main Board Replacement: 3 단계, 이미지 3개 중 2개 InFocus LP540 Projector Main Board Replacement: 3 단계, 이미지 3개 중 3개
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      댓글 쓰기
    4. InFocus LP540 Projector Main Board Replacement: 4 단계, 이미지 2개 중 1개 InFocus LP540 Projector Main Board Replacement: 4 단계, 이미지 2개 중 2개
      • Hold down the release tabs to remove the cables from the white tabs.
      댓글 쓰기
    5. InFocus LP540 Projector Main Board Replacement: 5 단계, 이미지 3개 중 1개 InFocus LP540 Projector Main Board Replacement: 5 단계, 이미지 3개 중 2개 InFocus LP540 Projector Main Board Replacement: 5 단계, 이미지 3개 중 3개
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      댓글 쓰기
    6. InFocus LP540 Projector Main Board Replacement: 6 단계, 이미지 3개 중 1개 InFocus LP540 Projector Main Board Replacement: 6 단계, 이미지 3개 중 2개 InFocus LP540 Projector Main Board Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jorge L Navarro
회원 가입일: 01/22/14
533 평판
안내서 5개를 작성함
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 회원
CPSU-REGAN-W14S13G17
6 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 2,663
