주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus LP540 Projector Speakers Replacement
필요한 것
  1. InFocus LP540 Projector Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 1개 InFocus LP540 Projector Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 2개 InFocus LP540 Projector Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 3개
    • Flip the projector right-side up and turn it so the backports face you.
    • Remove the 7mm metallic hex screws using the screwdriver.
    • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
    댓글 쓰기
  2. InFocus LP540 Projector Speakers Replacement: 2 단계, 이미지 2개 중 1개 InFocus LP540 Projector Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 77mm screws that are located nearest to the back panel ports using a T10 Torx screwdriver.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver.
    • Flip the projector back over.
    • Cautiously lift the main lid to avoid ripping the electrical strips.
    댓글 쓰기
  3. InFocus LP540 Projector Speakers Replacement: 3 단계, 이미지 2개 중 1개 InFocus LP540 Projector Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    댓글 쓰기
  4. InFocus LP540 Projector Speakers Replacement: 4 단계, 이미지 3개 중 1개 InFocus LP540 Projector Speakers Replacement: 4 단계, 이미지 3개 중 2개 InFocus LP540 Projector Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Place the top shell of the projector down.
    • Remove the speaker wires from the white tabs.
    • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws.
    • Carefully lift the speakers to remove them.
    댓글 쓰기
결론
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Jorge L Navarro
회원 가입일: 01/22/14
533 평판
안내서 5개를 작성함
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 회원
CPSU-REGAN-W14S13G17
6 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 900
