주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus Remote Front Cover Replacement
필요한 것
    1. InFocus Remote Front Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 InFocus Remote Front Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
      • Use your finger to press the tab on the battery cover.
      • Lift the cover up and out.
      댓글 쓰기
    2. InFocus Remote Front Cover Replacement: 2 단계, 이미지 2개 중 1개 InFocus Remote Front Cover Replacement: 2 단계, 이미지 2개 중 2개
      • Use your finger to lift the two AA batteries up and out of the remote.
      댓글 쓰기
    3. InFocus Remote Front Cover Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the three 9mm Phillips #00 screws located on the backside of the remote.
      댓글 쓰기
    4. InFocus Remote Front Cover Replacement: 4 단계, 이미지 2개 중 1개 InFocus Remote Front Cover Replacement: 4 단계, 이미지 2개 중 2개
      • Insert a plastic opening tool into the seam between the black top cover and silver base at the bottom edge of the remote.
      • Carefully pry the top cover up and away from the base.
      댓글 쓰기
    5. InFocus Remote Front Cover Replacement: 5 단계, 이미지 3개 중 1개 InFocus Remote Front Cover Replacement: 5 단계, 이미지 3개 중 2개 InFocus Remote Front Cover Replacement: 5 단계, 이미지 3개 중 3개
      • Insert an opening pick into the seam on side of the remote, even with the InFocus Label.
      • Slide the opening pick along the side of the remote, moving towards the buttons.
      • There is a plastic tab that holds the covers to the base, located even with the Source button. Push the pick through with a bit more force here to disconnect the cover.
      댓글 쓰기
    6. InFocus Remote Front Cover Replacement: 6 단계, 이미지 3개 중 1개 InFocus Remote Front Cover Replacement: 6 단계, 이미지 3개 중 2개 InFocus Remote Front Cover Replacement: 6 단계, 이미지 3개 중 3개
      • Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose.
      댓글 쓰기
    7. InFocus Remote Front Cover Replacement: 7 단계, 이미지 2개 중 1개 InFocus Remote Front Cover Replacement: 7 단계, 이미지 2개 중 2개
      • Firmly grasp the cover and lift it away from the remote.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Paige Reisman
회원 가입일: 04/07/14
24,175 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 35
전체 시간: 626
