주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
InFocus Screenplay 4805 Lamp Rebuild
필요한 것
    1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 1 단계, 이미지 2개 중 1개 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 1 단계, 이미지 2개 중 2개
      • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
      • Slide the bulb housing out of the projector.
      • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
      댓글 쓰기
    2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 2 단계, 이미지 2개 중 1개 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 2 단계, 이미지 2개 중 2개
      • This step is only required when rebuilding the old lamp with a replacement bulb.
      • Gently pull the top of the bulb housing off.
      • Lift up the middle of the bulb housing to remove it.
      • Be careful of loose parts, such as the metal housing and the glass focusing lens.
      댓글 쓰기
    3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 3 단계, 이미지 3개 중 1개 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 3 단계, 이미지 3개 중 2개 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 3 단계, 이미지 3개 중 3개
      • Unhook the spring from the bulb housing.
      • Gently remove the bulb.
      댓글 쓰기
결론
To reassemble the device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
Marilyn Urness
회원 가입일: 09/28/17
671 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 19
전체 시간: 169
