주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
India Mark II Chain Replacement
필요한 것
    1. India Mark II Chain Replacement, Access Door: 1 단계, 이미지 2개 중 1개 India Mark II Chain Replacement, Access Door: 1 단계, 이미지 2개 중 2개
      • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
      • Remove the hex head bolt from the top of the access door on the pump head.
      • On reassembly, this bolt should be hand-tight.
      댓글 쓰기
    2. India Mark II Chain Replacement: 2 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 2 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 2 단계, 이미지 3개 중 3개
      • Pull the access door straight up off the pump head.
      • Store the access door in a sanitary place to prevent contamination.
      댓글 쓰기
    3. India Mark II Chain Replacement: 3 단계, 이미지 2개 중 1개 India Mark II Chain Replacement: 3 단계, 이미지 2개 중 2개
      • The access door has a tongue that fits into the base of the pump head.
      • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
      댓글 쓰기
    1. India Mark II Chain Replacement, Chain: 4 단계, 이미지 3개 중 1개 India Mark II Chain Replacement, Chain: 4 단계, 이미지 3개 중 2개 India Mark II Chain Replacement, Chain: 4 단계, 이미지 3개 중 3개
      • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
      댓글 쓰기
    2. India Mark II Chain Replacement: 5 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 5 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 5 단계, 이미지 3개 중 3개
      • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
      • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
      댓글 쓰기
    3. India Mark II Chain Replacement: 6 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 6 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 6 단계, 이미지 3개 중 3개
      • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
      댓글 쓰기
    4. India Mark II Chain Replacement: 7 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 7 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 7 단계, 이미지 3개 중 3개
      • Hold the wrench on the bolt stationary.
      • Loosen the nut.
      댓글 쓰기
    5. India Mark II Chain Replacement: 8 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 8 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the nut from the chain bolt.
      댓글 쓰기
    6. India Mark II Chain Replacement: 9 단계, 이미지 2개 중 1개 India Mark II Chain Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the washer from the chain bolt.
      댓글 쓰기
    7. India Mark II Chain Replacement: 10 단계, 이미지 2개 중 1개 India Mark II Chain Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the chain bolt.
      댓글 쓰기
    8. India Mark II Chain Replacement: 11 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 11 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 11 단계, 이미지 3개 중 3개
      • Pull the top of the chain straight off of the pump handle.
      댓글 쓰기
    1. India Mark II Chain Replacement, Head: 12 단계, 이미지 3개 중 1개 India Mark II Chain Replacement, Head: 12 단계, 이미지 3개 중 2개 India Mark II Chain Replacement, Head: 12 단계, 이미지 3개 중 3개
      • Remove the two bolts from the handle side of the pump head.
      • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
      댓글 쓰기
    2. India Mark II Chain Replacement: 13 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 13 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 13 단계, 이미지 3개 중 3개
      • Remove the two bolts and nuts from the handle side.
      댓글 쓰기
    3. India Mark II Chain Replacement: 14 단계, 이미지 2개 중 1개 India Mark II Chain Replacement: 14 단계, 이미지 2개 중 2개
      • After removing the two handle side bolts, have your partner support the weight of the handle.
      • Remove the two remaining bolts in the same fashion.
      댓글 쓰기
    4. India Mark II Chain Replacement: 15 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 15 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 15 단계, 이미지 3개 중 3개
      • Lift and remove the pump head from the pump.
      • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
      댓글 쓰기
    1. India Mark II Chain Replacement, Chain: 16 단계, 이미지 2개 중 1개 India Mark II Chain Replacement, Chain: 16 단계, 이미지 2개 중 2개
      • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
      댓글 쓰기
    2. India Mark II Chain Replacement: 17 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 17 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 17 단계, 이미지 3개 중 3개
      • Lift the head flange up about one foot above the tank.
      댓글 쓰기
    3. India Mark II Chain Replacement: 18 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 18 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 18 단계, 이미지 3개 중 3개
      • Slide the rod clamp around the pump rod, and support it on the tank base.
      • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
      댓글 쓰기
    4. India Mark II Chain Replacement: 19 단계, 이미지 2개 중 1개 India Mark II Chain Replacement: 19 단계, 이미지 2개 중 2개
      • Tighten the rod clamp against the pump rod.
      • Be sure the pump rod is centered within the jaws of the clamp and held securely.
      댓글 쓰기
    5. India Mark II Chain Replacement: 20 단계, 이미지 2개 중 1개 India Mark II Chain Replacement: 20 단계, 이미지 2개 중 2개
      • Lower the head flange.
      댓글 쓰기
    6. India Mark II Chain Replacement: 21 단계, 이미지 3개 중 1개 India Mark II Chain Replacement: 21 단계, 이미지 3개 중 2개 India Mark II Chain Replacement: 21 단계, 이미지 3개 중 3개
      • Unscrew the chain from the top of the pump rod.
      • Remove the chain.
      • Check the chain for signs of wear or damage.
      • Set the chain in a sanitary place, such as the access door that was previously removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
515,490 평판
안내서 406개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 58,260개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 47
전체 시간: 1,485
