주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia Flex 8 Screen Replacement
필요한 것
    1. Insignia Flex 8 Screen Replacement, Circuit Board: 1 단계, 이미지 1개 중 1개
      • Turn off the power to your tablet to avoid injury.
      • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
      • Hold down the power button for five seconds until the tablet powers down.
      댓글 쓰기
    2. Insignia Flex 8 Screen Replacement: 2 단계, 이미지 2개 중 1개 Insignia Flex 8 Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • You may need to use a spudger to initially create separation between the screen and the casing.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      댓글 쓰기
    3. Insignia Flex 8 Screen Replacement: 3 단계, 이미지 2개 중 1개 Insignia Flex 8 Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
      댓글 쓰기
    4. Insignia Flex 8 Screen Replacement: 4 단계, 이미지 3개 중 1개 Insignia Flex 8 Screen Replacement: 4 단계, 이미지 3개 중 2개 Insignia Flex 8 Screen Replacement: 4 단계, 이미지 3개 중 3개
      • To remove the camera ribbon cable, lift the flap using a spudger.
      • Pull the ribbon directly back to release it.
      댓글 쓰기
    5. Insignia Flex 8 Screen Replacement: 5 단계, 이미지 3개 중 1개 Insignia Flex 8 Screen Replacement: 5 단계, 이미지 3개 중 2개 Insignia Flex 8 Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the second ribbon cable by prying up the black flap using a spudger.
      • Pull the ribbon cable horizontally directly away from the battery.
      댓글 쓰기
    6. Insignia Flex 8 Screen Replacement: 6 단계, 이미지 3개 중 1개 Insignia Flex 8 Screen Replacement: 6 단계, 이미지 3개 중 2개 Insignia Flex 8 Screen Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
      • Pull the ribbon horizontally directly away from the battery.
      댓글 쓰기
    7. Insignia Flex 8 Screen Replacement: 7 단계, 이미지 2개 중 1개 Insignia Flex 8 Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
      댓글 쓰기
    8. Insignia Flex 8 Screen Replacement: 8 단계, 이미지 2개 중 1개 Insignia Flex 8 Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
      • Lift up the circuit board.
      댓글 쓰기
    9. Insignia Flex 8 Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Unscrew the final two screws that were underneath the circuit board.
      • These screws are near the charging port and USB adapter.
      • These screws are also 3.75mm and can be interchanged with the second set of screws only.
      댓글 쓰기
    10. Insignia Flex 8 Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Lift the circuit board and black internal mounting piece away from the screen.
      • Set the circuit board aside.
      • Be careful of the soldered antenna as you separate the pieces.
      • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
      댓글 쓰기
    1. Insignia Flex 8 Screen Replacement, Screen: 11 단계, 이미지 1개 중 1개
      • Slide the spudger in between the silver screen and the black border
      댓글 쓰기
    2. Insignia Flex 8 Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Pry up the LCD display and lift it away from the plastic screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tyler Tyrrell
회원 가입일: 03/11/15
890 평판
안내서 4개를 작성함
Colorado Springs, Team 5-5, Panko Spring 2015 Colorado Springs, Team 5-5, Panko Spring 2015 회원
UCCS-PANKO-S15S5G5
3 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 43
전체 시간: 8,683
