주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Insignia NS-CSPBTHOL-R Power Button Replacement
필요한 것
  1. Insignia NS-CSPBTHOL-R Power Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
    댓글 쓰기
  2. Insignia NS-CSPBTHOL-R Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
    댓글 쓰기
  3. Insignia NS-CSPBTHOL-R Power Button Replacement: 3 단계, 이미지 2개 중 1개 Insignia NS-CSPBTHOL-R Power Button Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the grated panel off.
    댓글 쓰기
  4. Insignia NS-CSPBTHOL-R Power Button Replacement: 4 단계, 이미지 2개 중 1개 Insignia NS-CSPBTHOL-R Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
    댓글 쓰기
  5. Insignia NS-CSPBTHOL-R Power Button Replacement: 5 단계, 이미지 2개 중 1개 Insignia NS-CSPBTHOL-R Power Button Replacement: 5 단계, 이미지 2개 중 2개
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
    댓글 쓰기
  6. Insignia NS-CSPBTHOL-R Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
    댓글 쓰기
  7. Insignia NS-CSPBTHOL-R Power Button Replacement: 7 단계, 이미지 2개 중 1개 Insignia NS-CSPBTHOL-R Power Button Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
    댓글 쓰기
  8. Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: 8 단계, 이미지 3개 중 1개 Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: 8 단계, 이미지 3개 중 2개 Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, detach the power button from the mother board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Judith Villegas
회원 가입일: 02/15/17
327 평판
안내서 2개를 작성함
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G6
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 32
전체 시간: 870
