주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Installing MacBook Core 2 Duo Dual Hard Drive
필요한 것
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Battery: 1 단계, 이미지 1개 중 1개
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 2 단계, 이미지 1개 중 1개
      • Lift the battery out of the computer.
      댓글 쓰기
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Memory Cover: 3 단계, 이미지 1개 중 1개
      • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover so you cannot lose them.
      • Using The Flexible Extension sold by iFixit will help with this step.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 4 단계, 이미지 1개 중 1개
      • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
      • Lift the memory cover up and out of the computer.
      댓글 쓰기
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Upper Case: 5 단계, 이미지 1개 중 1개
      • Remove the following 3 screws:
      • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
      • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle of the lower case.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 6 단계, 이미지 1개 중 1개
      • Take extra caution with these screws as they can strip easily!
      • You could use a flexible extension to minimize stripping.
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
      • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
      댓글 쓰기
    3. Installing MacBook Core 2 Duo Dual Hard Drive: 7 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
      댓글 쓰기
    4. Installing MacBook Core 2 Duo Dual Hard Drive: 8 단계, 이미지 1개 중 1개
      • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
      • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
      댓글 쓰기
    5. Installing MacBook Core 2 Duo Dual Hard Drive: 9 단계, 이미지 1개 중 1개
      • Remove the following 4 screws from the back of the computer:
      • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
      댓글 쓰기
    6. Installing MacBook Core 2 Duo Dual Hard Drive: 10 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws from the optical drive (right) side of the computer:
      • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
      • It is not necessary to remove the similar screws on the ports (left) side of the computer.
      댓글 쓰기
    7. Installing MacBook Core 2 Duo Dual Hard Drive: 11 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
      • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
      • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
      • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
      댓글 쓰기
    8. Installing MacBook Core 2 Duo Dual Hard Drive: 12 단계, 이미지 3개 중 1개 Installing MacBook Core 2 Duo Dual Hard Drive: 12 단계, 이미지 3개 중 2개 Installing MacBook Core 2 Duo Dual Hard Drive: 12 단계, 이미지 3개 중 3개
      • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
      • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
      • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
      댓글 쓰기
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Optical Drive: 13 단계, 이미지 1개 중 1개
      • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 14 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws from the side of the optical drive.
      • Two 3.25 mm Phillips #000 (head: 4 mm. dia. x .3 mm thick)
      댓글 쓰기
    3. Installing MacBook Core 2 Duo Dual Hard Drive: 15 단계, 이미지 1개 중 1개
      • Disconnect the orange optical drive ribbon cable connector from the logic board by prying it straight up using either a finger or a spudger.
      댓글 쓰기
    4. Installing MacBook Core 2 Duo Dual Hard Drive: 16 단계, 이미지 1개 중 1개
      • Disconnect the newly revealed display data cable's plug from the logic board by pulling it upward using its black pull-tab.
      • If there is no pull-tab on top of the plug, it may be helpful to use a spudger to disconnect this plug.
      댓글 쓰기
    5. Installing MacBook Core 2 Duo Dual Hard Drive: 17 단계, 이미지 1개 중 1개
      • Disconnect the newly-revealed hard drive cable's plug from the logic board by pulling it upward using its black tab.
      • When reconnecting the hard drive cable's plug to the logic board, make sure the plug is routed under the cables for the right speaker and the microphone, or else the plug won't sit flush with the logic board, which will prevent the plug from fully engaging with its socket on the logic board.
      댓글 쓰기
    6. Installing MacBook Core 2 Duo Dual Hard Drive: 18 단계, 이미지 1개 중 1개
      • Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
      • During reassembly, be sure to route the cables beneath the tape before reattaching it.
      • If the adhesive on this foil tape no longer sticks, you can hold it in place using a regular piece of tape, but don't block the fan intake.
      댓글 쓰기
    7. Installing MacBook Core 2 Duo Dual Hard Drive: 19 단계, 이미지 1개 중 1개
      • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
      댓글 쓰기
    8. Installing MacBook Core 2 Duo Dual Hard Drive: 20 단계, 이미지 1개 중 1개
      • Remove the 2 mm Phillips #00 screw securing the rear corner of the optical drive.
      • When reinstalling this screw, make sure none of the cables nearby get caught under the screw's head.
      • The silver-jacketed Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to remove the screw holding the ground shield lugs for the two nearby cables before you can move the Bluetooth cable aside sufficiently. This screw is 7mm in earlier models, and may be 4.2mm in Santa Rosa/Penryn and 2009 models.
      댓글 쓰기
    9. Installing MacBook Core 2 Duo Dual Hard Drive: 21 단계, 이미지 1개 중 1개
      • Lift the Bluetooth antenna board from the front edge of the optical drive.
      댓글 쓰기
    10. Installing MacBook Core 2 Duo Dual Hard Drive: 22 단계, 이미지 1개 중 1개
      • Deroute the hard drive cable from under the clips along the near side of the optical drive.
      • During reassembly, reroute the cable under these clips.
      댓글 쓰기
    11. Installing MacBook Core 2 Duo Dual Hard Drive: 23 단계, 이미지 1개 중 1개
      • Lift the side of the optical drive closest to you, then slide the drive towards you, and up and out of the computer.
      • Follow these steps to reinstall the optical drive:
      • First, slide its side nearest to the rear of the Macbook under the edge of the rear frame to the left of the hinge, while also sliding the optical drive's mounting tab at its upper left corner under the cables at this location.
      • Lower the drive partially into the lower housing. Keep the hard drive cable away from the optical drive bay.
      • Before dropping the drive fully in place, use a spudger to push forward (towards the front of the drive) on the screw hole in the drive's mounting tab.
      • Push forward the slider, which runs along the far side of the drive, to insert the end of this slider into a small channel in the lower case's frame. This helps hold the drive in place.
      • When you push the slider forward, if the screw hole in the drive's mounting tab doesn't line up over its threaded brass insert in the lower case, the front end of the slider hasn't fully inserted into its channel in the frame. Keep trying, but if the slider won't move further to the right, remove the drive to see if the end of the slider is bent.
      • If the front end of the slider isn't bent, it may be slightly too long. Use a pair of fine cutters to clip off the narrower portion of the end of the slider. The optical drive will still remain firmly in place.
      댓글 쓰기
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Optical Drive Cable: 24 단계, 이미지 1개 중 1개
      • Peel up the black tape partially covering the orange optical drive cable.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 25 단계, 이미지 1개 중 1개
      • Disconnect the orange cable from the optical drive.
      댓글 쓰기
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Optical Drive: 26 단계, 이미지 1개 중 1개
      • Use a spudger to carefully pry the silver metal bracket off the left side of the optical drive. Be careful not to bend the bracket, as it is very thin and bends easily. If the bracket doesn't come free easily, heating the adhesive may make prying the bracket off easier.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 27 단계, 이미지 1개 중 1개
      • Peel up the L-shaped piece of black tape from the top of the drive.
      • You'll want to reapply this tape in the same position on your replacement drive.
      댓글 쓰기
    3. Installing MacBook Core 2 Duo Dual Hard Drive: 28 단계, 이미지 1개 중 1개
      • Peel up the silver foil tape from the optical drive.
      댓글 쓰기
    4. Installing MacBook Core 2 Duo Dual Hard Drive: 29 단계, 이미지 1개 중 1개
      • Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
      • This bracket is designed to slide back and forth slightly, so don't tighten the screws so much that the bracket is unable to slide.
      댓글 쓰기
    5. Installing MacBook Core 2 Duo Dual Hard Drive: 30 단계, 이미지 1개 중 1개
      • Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
      • You'll want to reapply this piece in the same position on your replacement drive.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      댓글 쓰기
    1. Installing MacBook Core 2 Duo Dual Hard Drive, Dual Hard Drive: 31 단계, 이미지 2개 중 1개 Installing MacBook Core 2 Duo Dual Hard Drive, Dual Hard Drive: 31 단계, 이미지 2개 중 2개
      • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
      댓글 쓰기
    2. Installing MacBook Core 2 Duo Dual Hard Drive: 32 단계, 이미지 3개 중 1개 Installing MacBook Core 2 Duo Dual Hard Drive: 32 단계, 이미지 3개 중 2개 Installing MacBook Core 2 Duo Dual Hard Drive: 32 단계, 이미지 3개 중 3개
      • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
      • Gently place the hard drive into the enclosure's hard drive slot.
      • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
      댓글 쓰기
    3. Installing MacBook Core 2 Duo Dual Hard Drive: 33 단계, 이미지 2개 중 1개 Installing MacBook Core 2 Duo Dual Hard Drive: 33 단계, 이미지 2개 중 2개
      • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
      • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 69명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jake Devincenzi
회원 가입일: 04/18/11
119,434 평판
안내서 57개를 작성함
7가이드 댓글
great guide, but it was more than moderately difficult for me. thanks guys
Jason C - 답글 공유
I just successful follow this guide to add 2nd hard drive to my old Macbook White 4.1. It really helpful, just a part take me some time. It is bluetooth atena board part, it cause my keyboard got big gap. Finally I hide it below my Optibay, so far the bluetooth still working well. Thanks iFix. :D
Jay - 답글 공유
only took about 10-15 minutes for me when i was practicing on my broken Macbook white(as not to risk my new one), this guide is the best one i've seen yet, it is a little bit harder than moderate when you don't have a small phillips screwdriver though, but my steak knife worked pretty well too, thanks guys
Ziggy Brown - 답글 공유
Thanks, I used this guide to reuse the hard drive as an external.
Random Tech - 답글 공유
J'installe ssd PNY dans la boîtier, mais mbp ne reconnaît pas ce ssd. Merci pour m'aider à fixit.
Wenbo GONG - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 25
지난 30일: 96
전체 시간: 101,645
