주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive
필요한 것
    1. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Lower Case: 1 단계, 이미지 1개 중 1개
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      댓글 쓰기
    2. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 2 단계, 이미지 1개 중 1개
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      댓글 쓰기
    1. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Battery Connector: 3 단계, 이미지 2개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Battery Connector: 3 단계, 이미지 2개 중 2개
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
      댓글 쓰기
    2. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 4 단계, 이미지 1개 중 1개
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      댓글 쓰기
    1. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Optical Drive: 5 단계, 이미지 1개 중 1개
      • Disconnect the camera cable connector from its socket on the logic board.
      • Do not lift up on the cable as you disconnect it from the logic board. Pull the cable parallel to the face of the logic board.
      댓글 쓰기
    2. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 6 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
      댓글 쓰기
    3. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 7 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
      댓글 쓰기
    4. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 8 단계, 이미지 2개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 8 단계, 이미지 2개 중 2개
      • Remove following two screws:
      • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
      • One 8.6 mm Phillips screw
      • One 3.9 mm Phillips screw
      • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
      댓글 쓰기
    5. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 9 단계, 이미지 1개 중 1개
      • Remove the three 3.5 mm T6 Torx screws securing the optical drive to the upper case.
      댓글 쓰기
    6. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 10 단계, 이미지 1개 중 1개
      • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
      댓글 쓰기
    1. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Optical Drive Cable: 11 단계, 이미지 2개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Optical Drive Cable: 11 단계, 이미지 2개 중 2개
      • Pull the optical drive cable out of the optical drive.
      • Be sure to pull by the edges of the connector, not by the cable itself.
      • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
      댓글 쓰기
    1. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Dual Hard Drive: 12 단계, 이미지 2개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive, Dual Hard Drive: 12 단계, 이미지 2개 중 2개
      • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
      댓글 쓰기
    2. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 13 단계, 이미지 3개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 13 단계, 이미지 3개 중 2개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 13 단계, 이미지 3개 중 3개
      • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
      • Gently place the hard drive into the enclosure's hard drive slot.
      • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
      댓글 쓰기
    3. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 14 단계, 이미지 2개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 14 단계, 이미지 2개 중 2개
      • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
      댓글 쓰기
    4. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 15 단계, 이미지 2개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 15 단계, 이미지 2개 중 2개
      • Use two Phillips #1 screws to secure the drive to its enclosure.
      댓글 쓰기
    5. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 16 단계, 이미지 1개 중 1개
      • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
      • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
      댓글 쓰기
    6. Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 17 단계, 이미지 3개 중 1개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 17 단계, 이미지 3개 중 2개 Installing MacBook Pro 15" Unibody Mid 2012 Dual Hard Drive: 17 단계, 이미지 3개 중 3개
      • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
      • Align the cable's SATA connector with the drive's port and plug in securely.
      • Plug the USB connector into your laptop and your optical drive is ready for use.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 123명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
515,490 평판
안내서 406개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 59,741개를 작성함
13가이드 댓글
great guide!
Pham Duc Hieu - 답글 공유
I had problems initialising the SDD drive in the optical bay. But have placed it in HD bay and it works fine.
My old Hard drive is a really snug fit in the caddy (its a 9.5mm drive) - when installed in the HD bay it sits on rubber shock absorbers and has air around it.
With a HD in the optical bay, I expect there to be some overheating or shock problems in the future.
Andrew - 답글 공유
!! Hard drive !! The Harddrive with the OS X on it for booting, has to be to be in the Harddisk bay and not the optical bay!
The System does only startup regularly on the SATA connector meant for the Harddrive, not the SATA connector of the former optical drive! (Even for MID 2012)
So, cause the most of us will add a SSD and want to run the System from it, we have to change the old Harddisk to the Optical bay where it is mounted without the anti shock rubbers.
In my case it did´t die there for over a year yet, so, not the big deal it seems at the first look ;-) lucky
pianogreg - 답글 공유
I have a mid-2012 MBP. I just replaced the superdrive with a Samsung Evo 840 1TB SSD. My mac will boot from this drive when it is in the primary bay, and also if it is connected externally with a USB3/SATA cable. However it will not boot from the optical drive bay.
Also, if I install my original drive (Seagate Momentus XT 750GB hybrid) in the optical drive bay it will not boot.
If however I install an old 5400 HDD in to the optical drive bay, it WILL boot.
All three of the above mentioned drives have the same cloned OS on them. When the hybrid or the SSD are installed in the optical drive bay I can see them in the system profiler; both read a negotiated link speed of 6g.
Am I missing something...?
Crumbs - 답글 공유
Crumbs :
Yes you are missing something… MPB MI2012 have just ONE Sata3 to read SSD… The sata for optical drive bay is on sata2.. So it can’t read SSD drive. Put your DD5400 on the optical drive bay, and boot with your SSD (install on the primary bay) and everything will be okay ;)!
Micke - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 111
전체 시간: 136,327
