주요 콘텐츠로 건너뛰기
Installing Sewing Machine Bobbin
필요한 것
  1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: 1 단계, 이미지 2개 중 1개 Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: 1 단계, 이미지 2개 중 2개
    • Use your finger to open the bobbin door below the presser foot.
  2. Installing Sewing Machine Bobbin: 2 단계, 이미지 2개 중 1개 Installing Sewing Machine Bobbin: 2 단계, 이미지 2개 중 2개
    • Align the hole in the bobbin spindle over the peg in the bobbin case.
    • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
    • Take the loose thread end and slide it through the slit on the side of the bobbin case.
    So do you have the thread coming out to the right like the photo or to the left ?
    Rebecca Petts - 답글
  3. Installing Sewing Machine Bobbin: 3 단계, 이미지 2개 중 1개 Installing Sewing Machine Bobbin: 3 단계, 이미지 2개 중 2개
    • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
  4. Installing Sewing Machine Bobbin: 4 단계, 이미지 2개 중 1개 Installing Sewing Machine Bobbin: 4 단계, 이미지 2개 중 2개
    • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
    • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
  5. Installing Sewing Machine Bobbin: 5 단계, 이미지 2개 중 1개 Installing Sewing Machine Bobbin: 5 단계, 이미지 2개 중 2개
    • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
    • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
    • Release the bobbin case.
  6. Installing Sewing Machine Bobbin: 6 단계, 이미지 2개 중 1개 Installing Sewing Machine Bobbin: 6 단계, 이미지 2개 중 2개
    • Close the door on the compartment below the presser foot.
    You should leave a tail of thread sticking out of the compartment door. This creates tension and allows the bobbin thread to be pulled up correctly to the sewing surface. Once the bobbin thread is 'up', then you can put the table back in place.
    jodyvalerie - 답글
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,748 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
119 회원들
안내서 19,523개를 작성함
댓글 한 개
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - 답글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 76
지난 30일: 341
전체 시간: 54,392
