주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Intertek 20006 Fan Replacement
필요한 것
    1. Intertek 20006 Fan Replacement, Fan: 1 단계, 이미지 2개 중 1개 Intertek 20006 Fan Replacement, Fan: 1 단계, 이미지 2개 중 2개
      • Turn off the air humidifier using the 0/1 switch at the bottom edge of back side.
      • Hold the top-back of the air humidifier and remove the upper part from the lower part.
      • Remove water from the water chamber and wipe it.
      댓글 쓰기
    2. Intertek 20006 Fan Replacement: 2 단계, 이미지 3개 중 1개 Intertek 20006 Fan Replacement: 2 단계, 이미지 3개 중 2개 Intertek 20006 Fan Replacement: 2 단계, 이미지 3개 중 3개
      • Flip the humidifier so that the bottom is facing upwards.
      • Use a Phillips # 2 screwdriver to remove four 13 mm screws from the bottom cover hole.
      • Remove the bottom cover to access the fan and other parts of the humidifier.
      댓글 쓰기
    3. Intertek 20006 Fan Replacement: 3 단계, 이미지 2개 중 1개 Intertek 20006 Fan Replacement: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #2 screwdriver to remove four 30 mm screws from the fan.
      • Remove the fan from its place and keep it close to its power connector.
      댓글 쓰기
    4. Intertek 20006 Fan Replacement: 4 단계, 이미지 2개 중 1개 Intertek 20006 Fan Replacement: 4 단계, 이미지 2개 중 2개
      • Using a spudger, straighten all three metal latches.
      • Hold both edges of the metal cover with your finger and pull upward to take it out from its position.
      • Metal cover edges are very sharp. Watch your finger when holding the metal cover.
      댓글 쓰기
    5. Intertek 20006 Fan Replacement: 5 단계, 이미지 3개 중 1개 Intertek 20006 Fan Replacement: 5 단계, 이미지 3개 중 2개 Intertek 20006 Fan Replacement: 5 단계, 이미지 3개 중 3개
      • Pull out the power connector of the fan from its port.
      • Use a wire cutter to cut the tie rope around the wires.
      • When cutting the tie rope, take care to avoid cutting any cables.
      • Remove the fan from the humidifier.
      • Plug in the new fan's power connector.
      • Tie all cables together using a twist tie.
      댓글 쓰기
    6. Intertek 20006 Fan Replacement: 6 단계, 이미지 3개 중 1개 Intertek 20006 Fan Replacement: 6 단계, 이미지 3개 중 2개 Intertek 20006 Fan Replacement: 6 단계, 이미지 3개 중 3개
      • Attach the metal cover where it was before.
      • Bend the latches halfway down using a spudger to secure the metal cover.
      댓글 쓰기
    7. Intertek 20006 Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Secure the new fan with the four 30 mm screws using a Phillips #2 screwdriver.
      댓글 쓰기
    8. Intertek 20006 Fan Replacement: 8 단계, 이미지 2개 중 1개 Intertek 20006 Fan Replacement: 8 단계, 이미지 2개 중 2개
      • Put the bottom cover back in place.
      • Secure the bottom cover with the four 13 mm screws using a Phillips #2 screwdriver.
      • Flip the humidifier right-side up, and attach the upper part
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
[deleted]
회원 가입일: 05/08/20
184 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 43
전체 시간: 1,189
