주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ion Air Pro Body Cover Replacement
필요한 것
    1. Ion Air Pro Body Cover Replacement, Body Cover: 1 단계, 이미지 1개 중 1개
      • Unscrew all six screws.
      • Make sure you put the screws in a good spot where you won't lose them because they are small.
      댓글 쓰기
    2. Ion Air Pro Body Cover Replacement: 2 단계, 이미지 1개 중 1개
      • After you're done with unscrewing, take off the blue lid shown here.
      댓글 쓰기
    3. Ion Air Pro Body Cover Replacement: 3 단계, 이미지 1개 중 1개
      • On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
      댓글 쓰기
    4. Ion Air Pro Body Cover Replacement: 4 단계, 이미지 1개 중 1개
      • After removing the black lid, unscrew all eight screws here.
      • Again, make sure you keep track of your screws and don't lose them.
      댓글 쓰기
    5. Ion Air Pro Body Cover Replacement: 5 단계, 이미지 1개 중 1개
      • Remove two more screws, one on each side, inside this socket.
      댓글 쓰기
    6. Ion Air Pro Body Cover Replacement: 6 단계, 이미지 1개 중 1개
      • Next, unscrew the two screws located here.
      댓글 쓰기
    7. Ion Air Pro Body Cover Replacement: 7 단계, 이미지 1개 중 1개
      • Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
      • Everything inside is still connected with all the wires, so be careful not to pull too hard or else everything inside could fall out or get broken.
      댓글 쓰기
    8. Ion Air Pro Body Cover Replacement: 8 단계, 이미지 1개 중 1개
      • Finally, you can remove the body cover off and replace it with a new one if you have to.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Christopher Brandl
회원 가입일: 10/09/18
673 평판
안내서 5개를 작성함
UW Stout, Team S6-G2, Ogden Fall 2018 UW Stout, Team S6-G2, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G2
4 회원들
안내서 5개를 작성함
5가이드 댓글
Hey Chris where can I buy a replacement body cover?
The thread of the screw socket on my ion air pro WiFi has worn out and it can no longer be screwed onto any mounts.
Sam s - 답글 공유
I LOST THE LOSTTHE REAR COVER WHILE HUNTING. iS THERE A REPLACEMENT I CAN GET
mcbee1010 - 답글 공유
i lost the rear cover cap while hunting. can i purchase a new one
mcbee1010 - 답글 공유
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
Andrew Mawby - 답글 공유
Help: How to replace the battery, mine won't charge?
Kevin Harmon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 1,156
