주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ivation IVWPDC20Y Flash Bulb Replacement
필요한 것
  1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: 1 단계, 이미지 1개 중 1개
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
    댓글 쓰기
  2. Ivation IVWPDC20Y Flash Bulb Replacement: 2 단계, 이미지 1개 중 1개
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
    댓글 쓰기
  3. Ivation IVWPDC20Y Flash Bulb Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
    댓글 쓰기
  4. Ivation IVWPDC20Y Flash Bulb Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
    댓글 쓰기
  5. Ivation IVWPDC20Y Flash Bulb Replacement: 5 단계, 이미지 1개 중 1개
    • Pry off back outer casing using the black spudger or the blue prying tools
    댓글 쓰기
  6. Ivation IVWPDC20Y Flash Bulb Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
    댓글 쓰기
  7. Ivation IVWPDC20Y Flash Bulb Replacement: 7 단계, 이미지 1개 중 1개
    • Gently push out the pins holding the orange tape down using the pointy end of the spudger
    • Screen and orange tape should slip out as a whole
    댓글 쓰기
  8. Ivation IVWPDC20Y Flash Bulb Replacement: 8 단계, 이미지 1개 중 1개
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
    댓글 쓰기
  9. Ivation IVWPDC20Y Flash Bulb Replacement: 9 단계, 이미지 1개 중 1개
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
    댓글 쓰기
  10. Ivation IVWPDC20Y Flash Bulb Replacement: 10 단계, 이미지 1개 중 1개
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
    댓글 쓰기
  11. Ivation IVWPDC20Y Flash Bulb Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the soldering on the three wires holding the flash bulb
    • The wires are different colors: red, white, and black
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Wendy Jones
회원 가입일: 02/06/16
225 평판
안내서 2개를 작성함
USF Tampa, Team 6-6, Eyestone Spring 2016 USF Tampa, Team 6-6, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G6
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 511
