주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
J. Preflight Checklist-Endstops
  1. J. Preflight Checklist-Endstops, End Stops: 1 단계, 이미지 2개 중 1개 J. Preflight Checklist-Endstops, End Stops: 1 단계, 이미지 2개 중 2개
    • Make sure none of the end stops are triggered.
    • Manually trigger the X end stop and re enter M119. It should return a status of "at min stop" for X and Y should say "not stopped"
    • Manually trigger the Y end stop and re enter M119. It should return a status of "at max stop" for Y and X should say "not stopped"
    댓글 쓰기
  2. J. Preflight Checklist-Endstops, BLTouch: 2 단계, 이미지 1개 중 1개
    • You should have a Macros folder for your BLTouch. Select Deploy, the pin should deploy. Select Retract, the pin should retract.
    • If the BLTouch starts blinking at any point normally it's a bad connection check your wiring.
    • Occasionally running the "Alarm Release Pin Up" macro can solve a blinking BLTouch
    댓글 쓰기
    • Heat the nozzle to 200c and bed to 60c and wait for the temperatures to stabilize. Remove any filament that is stuck to the nozzle.
    • If you have independent axis leveling configured make sure you run. Home all axis.
    • Jog the nozzle to the center of the bed. If using my github config, move the hotend X-40 so the nozzle is in the center of the bed.
    • Place a piece of paper under the nozzle.
    • A lot of times when calibrating Z offset the bed can't move up high enough because we don't have it configured to allow Z to go past 0. Out of habit when calibrating Z offset I will send G92 Z15 which tells the printer the new Z position is Z15. This will give me more than enough to calibrate the Z offset now.
    • In the console enter
    • M558 P9 C"^zprobe.in"
    • G31 P500 Z1.0
    댓글 쓰기
    • Jog the bed up carefully using the Z-.50 and Z-.05 buttons until the nozzle grips the paper
    • Once the nozzle grips the paper send G92 Z0
    • Lower the bed 10mm
    • Move the probe to bed center(same amount as step 3 but move it to the right)
    • Send G30 S-1. This will probe the bed and tell you the offset. Move the bed to Z10 and run G30 S-1 again. Repeat this step a couple of times. When finished move the bed to Z10.
    • Take the average of the Z offset readings from the console and replace your current G31 P500 X-42.45 Y0 Z## in config.g
    • Save and restart your printer
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Husolo
회원 가입일: 06/16/21
9,382 평판
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 1,096
