주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 3 Battery Replacement
필요한 것
    1. JBL Charge 3 Battery Replacement, Front Cover: 1 단계, 이미지 3개 중 1개 JBL Charge 3 Battery Replacement, Front Cover: 1 단계, 이미지 3개 중 2개 JBL Charge 3 Battery Replacement, Front Cover: 1 단계, 이미지 3개 중 3개
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      댓글 쓰기
    2. JBL Charge 3 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      댓글 쓰기
    1. JBL Charge 3 Battery Replacement, Passive Radiators: 3 단계, 이미지 3개 중 1개 JBL Charge 3 Battery Replacement, Passive Radiators: 3 단계, 이미지 3개 중 2개 JBL Charge 3 Battery Replacement, Passive Radiators: 3 단계, 이미지 3개 중 3개
      • Remove the two 8mm Phillips #1 screws from the tabs.
      • NOTE: There may be only one screw.
      댓글 쓰기
    2. JBL Charge 3 Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Charge 3 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Insert the plastic opening tools underneath both tabs.
      댓글 쓰기
    3. JBL Charge 3 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
      댓글 쓰기
    4. JBL Charge 3 Battery Replacement: 6 단계, 이미지 2개 중 1개 JBL Charge 3 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Repeat all previous steps for the other passive radiator.
      • NOTE: only the right radiator needs to be removed for changing the battery.
      댓글 쓰기
    1. JBL Charge 3 Battery Replacement, Battery: 7 단계, 이미지 3개 중 1개 JBL Charge 3 Battery Replacement, Battery: 7 단계, 이미지 3개 중 2개 JBL Charge 3 Battery Replacement, Battery: 7 단계, 이미지 3개 중 3개
      • Remove the six 8mm Phillips #1 screws from the outer battery cover.
      • Peel the outer battery cover away from the speaker housing.
      댓글 쓰기
    2. JBL Charge 3 Battery Replacement: 8 단계, 이미지 3개 중 1개 JBL Charge 3 Battery Replacement: 8 단계, 이미지 3개 중 2개 JBL Charge 3 Battery Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the seven 8mm Phillips #1 screws from interior battery cover.
      • Remove the interior battery cover.
      댓글 쓰기
    3. JBL Charge 3 Battery Replacement: 9 단계, 이미지 2개 중 1개 JBL Charge 3 Battery Replacement: 9 단계, 이미지 2개 중 2개
      • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
      댓글 쓰기
    4. JBL Charge 3 Battery Replacement: 10 단계, 이미지 1개 중 1개
      • Pull the battery and battery cable out from their housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 154명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jack Ng
회원 가입일: 10/08/18
2,446 평판
안내서 4개를 작성함
35가이드 댓글
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - 답글 공유
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Tomas Opmann - 답글 공유
thank you so much :D
punkzmarc - 답글 공유
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
Dom Heizmann - 답글 공유
I saw one on youtube taking the one from the old battery and putting it on the new one
Dominik Spreuer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 53
지난 7일: 371
지난 30일: 1,642
전체 시간: 273,032
