주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 3 Button Replacement
필요한 것
    1. JBL Charge 3 Button Replacement, Front Cover: 1 단계, 이미지 3개 중 1개 JBL Charge 3 Button Replacement, Front Cover: 1 단계, 이미지 3개 중 2개 JBL Charge 3 Button Replacement, Front Cover: 1 단계, 이미지 3개 중 3개
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      댓글 쓰기
    2. JBL Charge 3 Button Replacement: 2 단계, 이미지 1개 중 1개
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      댓글 쓰기
    1. JBL Charge 3 Button Replacement, Button: 3 단계, 이미지 2개 중 1개 JBL Charge 3 Button Replacement, Button: 3 단계, 이미지 2개 중 2개
      • Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
      • Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
      댓글 쓰기
    2. JBL Charge 3 Button Replacement: 4 단계, 이미지 2개 중 1개 JBL Charge 3 Button Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Flip open the top flap on the ZIF connector.
      • Gently pull out the ZIF connector cable with tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sunmin Yoon
회원 가입일: 10/30/18
2,096 평판
안내서 2개를 작성함
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 회원
CPSU-WHITE-F18S13G1
3 회원들
안내서 34개를 작성함
4가이드 댓글
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - 답글 공유
Where do i buy new buttons?
Thomas Bjerregaard - 답글 공유
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - 답글 공유
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 145
전체 시간: 28,711
