주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 3 Motherboard Replacement
필요한 것
    1. JBL Charge 3 Motherboard Replacement, Front Cover: 1 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement, Front Cover: 1 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement, Front Cover: 1 단계, 이미지 3개 중 3개
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      댓글 쓰기
    2. JBL Charge 3 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      댓글 쓰기
    1. JBL Charge 3 Motherboard Replacement, Passive Radiators: 3 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement, Passive Radiators: 3 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement, Passive Radiators: 3 단계, 이미지 3개 중 3개
      • Remove the two 8mm Phillips #1 screws from the tabs.
      • NOTE: There may be only one screw.
      댓글 쓰기
    2. JBL Charge 3 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Insert the plastic opening tools underneath both tabs.
      댓글 쓰기
    3. JBL Charge 3 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
      댓글 쓰기
    4. JBL Charge 3 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Repeat all previous steps for the other passive radiator.
      • NOTE: only the right radiator needs to be removed for changing the battery.
      댓글 쓰기
    1. JBL Charge 3 Motherboard Replacement, Speaker: 7 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement, Speaker: 7 단계, 이미지 2개 중 2개
      • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
      댓글 쓰기
    2. JBL Charge 3 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
      댓글 쓰기
    3. JBL Charge 3 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
      • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
      댓글 쓰기
    4. JBL Charge 3 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
      • Repeat the previous step for the second connector.
      댓글 쓰기
    5. JBL Charge 3 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
      댓글 쓰기
    6. JBL Charge 3 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
      • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
      댓글 쓰기
    1. JBL Charge 3 Motherboard Replacement, Battery: 13 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement, Battery: 13 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement, Battery: 13 단계, 이미지 3개 중 3개
      • Remove the six 8mm Phillips #1 screws from the outer battery cover.
      • Peel the outer battery cover away from the speaker housing.
      댓글 쓰기
    2. JBL Charge 3 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the seven 8mm Phillips #1 screws from interior battery cover.
      • Remove the interior battery cover.
      댓글 쓰기
    3. JBL Charge 3 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
      • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
      댓글 쓰기
    4. JBL Charge 3 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
      • Pull the battery and battery cable out from their housing.
      댓글 쓰기
    1. JBL Charge 3 Motherboard Replacement, Port Bay: 17 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement, Port Bay: 17 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement, Port Bay: 17 단계, 이미지 3개 중 3개
      • Take out the four 8mm Phillips #1 screws out of the port bay cover.
      • Wedge your plastic opening tool around the port bay to remove it.
      댓글 쓰기
    2. JBL Charge 3 Motherboard Replacement: 18 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement: 18 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement: 18 단계, 이미지 3개 중 3개
      • Disconnect the two bundled cable connector from the port bay.
      댓글 쓰기
    3. JBL Charge 3 Motherboard Replacement: 19 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement: 19 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement: 19 단계, 이미지 3개 중 3개
      • Remove the three 8mm Phillips #1 screws from the port bay circuit board.
      • Pull the port bay cover off of the circuit board.
      댓글 쓰기
    4. JBL Charge 3 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
      • Desolder the USB, MicroUSB, or AUX port off of the circuit board.
      댓글 쓰기
    1. JBL Charge 3 Motherboard Replacement, Motherboard: 21 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement, Motherboard: 21 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement, Motherboard: 21 단계, 이미지 3개 중 3개
      • Remove the two 9mm Phillips #1 screws holding in the sides of the motherboard.
      댓글 쓰기
    2. JBL Charge 3 Motherboard Replacement: 22 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 22 단계, 이미지 2개 중 2개
      • Gently pull the bundled cable connector on the motherboard.
      댓글 쓰기
    3. JBL Charge 3 Motherboard Replacement: 23 단계, 이미지 2개 중 1개 JBL Charge 3 Motherboard Replacement: 23 단계, 이미지 2개 중 2개
      • Gently pull the golden connector off of the motherboard.
      댓글 쓰기
    4. JBL Charge 3 Motherboard Replacement: 24 단계, 이미지 3개 중 1개 JBL Charge 3 Motherboard Replacement: 24 단계, 이미지 3개 중 2개 JBL Charge 3 Motherboard Replacement: 24 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Flip open the top flap on the two ZIF connectors.
      • Gently pull out the ZIF connector cables with tweezers.
      댓글 쓰기
    5. JBL Charge 3 Motherboard Replacement: 25 단계, 이미지 1개 중 1개
      • Slide the motherboard out of the housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sunmin Yoon
회원 가입일: 10/30/18
2,096 평판
안내서 2개를 작성함
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 회원
CPSU-WHITE-F18S13G1
3 회원들
안내서 34개를 작성함
14가이드 댓글
Internation version is different. There are no screws for passive radiotors.
Tr0ll05aur0s 3z - 답글 공유
You have to twist it. I have to managed to get it open because there is no video on youtube (I can’t find any)
If that even is Charge 3.
My JBL charge 3 is not charging …please give me idea to fix ..but it’s working perfectly only
nagendra.shriyan - 답글 공유
My jbl charge are charging but it won't turn on…… i have tried several times to turn it on but it won't turn…… hoping for solutions……
cire_012881 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 46
지난 30일: 229
전체 시간: 35,053
