주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 4 Battery Replacement
필요한 것
    1. JBL Charge 4 Battery Replacement, Speaker Grill: 1 단계, 이미지 1개 중 1개
      • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
      • Pry away from yourself towards the back of the speaker to release the clip.
      • Repeat this process for the clip on the other side.
      댓글 쓰기
    2. JBL Charge 4 Battery Replacement: 2 단계, 이미지 2개 중 1개 JBL Charge 4 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
      댓글 쓰기
    3. JBL Charge 4 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Pull apart both sides of the grille.
      • Lift the cover off of the speaker.
      댓글 쓰기
    1. JBL Charge 4 Battery Replacement, Passive Bass Radiators: 4 단계, 이미지 2개 중 1개 JBL Charge 4 Battery Replacement, Passive Bass Radiators: 4 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
      • Repeat this process on the other clips around the radiator to release it from the frame.
      댓글 쓰기
    2. JBL Charge 4 Battery Replacement: 5 단계, 이미지 2개 중 1개 JBL Charge 4 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Push the radiator off of the frame of the device.
      • Repeat on the other side.
      • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
      댓글 쓰기
    1. JBL Charge 4 Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 JBL Charge 4 Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
      • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
      댓글 쓰기
    2. JBL Charge 4 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Gently slide the cover back and off the hooks.
      • Remove the port bay cover.
      댓글 쓰기
    3. JBL Charge 4 Battery Replacement: 8 단계, 이미지 3개 중 1개 JBL Charge 4 Battery Replacement: 8 단계, 이미지 3개 중 2개 JBL Charge 4 Battery Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the two 6mm Phillips #0 screws.
      • Remove the four 8mm Phillips #0 screws.
      댓글 쓰기
    4. JBL Charge 4 Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Lift up the battery cover.
      댓글 쓰기
    5. JBL Charge 4 Battery Replacement: 10 단계, 이미지 3개 중 1개 JBL Charge 4 Battery Replacement: 10 단계, 이미지 3개 중 2개 JBL Charge 4 Battery Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the sticky tape to expose the white ribbon cable ZIF connector.
      • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
      • Remove the white ribbon cable from the battery cover and place the cover to the side.
      댓글 쓰기
    6. JBL Charge 4 Battery Replacement: 11 단계, 이미지 2개 중 1개 JBL Charge 4 Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the battery from the battery socket by gently pulling on it.
      댓글 쓰기
    7. JBL Charge 4 Battery Replacement: 12 단계, 이미지 3개 중 1개 JBL Charge 4 Battery Replacement: 12 단계, 이미지 3개 중 2개 JBL Charge 4 Battery Replacement: 12 단계, 이미지 3개 중 3개
      • Pull out the battery enough to expose the battery's wire connector.
      • Push down on the white tab and gently pull out the battery-device connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 31명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sydney Seto
회원 가입일: 01/24/19
990 평판
안내서 1개를 작성함
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 회원
CPSU-WHITE-W19S1G1
4 회원들
안내서 36개를 작성함
18가이드 댓글
Where do you buy a battery for a jbl Charge 4 ??
Matt hempel - 답글 공유
Probably just cut open the blue foil around the batteries and replace them by re-soldering the electronics onto new 18650 batteries.
correct me if I’m wrong here.
Brendon Reijnders - 답글 공유
If you know how to handle them and have experience with soldering them that's a yes if not those batteries are really dangerous if you don't know how to do it correctly.
Hart80 - 답글 공유
Where in the !&&* do i get a battery for a bluetooth speaker. What happened to the jbl charge 4 that it even goes out???
Shani Sanders - 답글 공유
My JBL charge 4 battery dead too. 9nly uses it for three months
osborne buhere - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 40
지난 7일: 233
지난 30일: 879
전체 시간: 86,487
