주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 4 Buttons Replacement
필요한 것
    1. JBL Charge 4 Buttons Replacement, Speaker Grill: 1 단계, 이미지 1개 중 1개
      • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
      • Pry away from yourself towards the back of the speaker to release the clip.
      • Repeat this process for the clip on the other side.
      댓글 쓰기
    2. JBL Charge 4 Buttons Replacement: 2 단계, 이미지 2개 중 1개 JBL Charge 4 Buttons Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
      댓글 쓰기
    3. JBL Charge 4 Buttons Replacement: 3 단계, 이미지 1개 중 1개
      • Pull apart both sides of the grille.
      • Lift the cover off of the speaker.
      댓글 쓰기
    1. JBL Charge 4 Buttons Replacement, Passive Bass Radiators: 4 단계, 이미지 2개 중 1개 JBL Charge 4 Buttons Replacement, Passive Bass Radiators: 4 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
      • Repeat this process on the other clips around the radiator to release it from the frame.
      댓글 쓰기
    2. JBL Charge 4 Buttons Replacement: 5 단계, 이미지 2개 중 1개 JBL Charge 4 Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Push the radiator off of the frame of the device.
      • Repeat on the other side.
      • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
      댓글 쓰기
    1. JBL Charge 4 Buttons Replacement, Buttons: 6 단계, 이미지 3개 중 1개 JBL Charge 4 Buttons Replacement, Buttons: 6 단계, 이미지 3개 중 2개 JBL Charge 4 Buttons Replacement, Buttons: 6 단계, 이미지 3개 중 3개
      • Lift up the tape covering the button control board ZIF connector on the left side of the motherboard.
      • Flip up the black locking flap on the ZIF connector with the tip of the spudger or your fingernail to release the white ribbon cable.
      댓글 쓰기
    2. JBL Charge 4 Buttons Replacement: 7 단계, 이미지 2개 중 1개 JBL Charge 4 Buttons Replacement: 7 단계, 이미지 2개 중 2개
      • Flip the speaker over so the buttons are on the top.
      • Using the plastic opening tool, pry up the rubber covering the button control board from the adhesive.
      • Remove the cover and set to the side.
      • By removing the rubber cover and the control board you are breaking adhesives that may result in the speaker no longer being waterproof.
      댓글 쓰기
    3. JBL Charge 4 Buttons Replacement: 8 단계, 이미지 3개 중 1개 JBL Charge 4 Buttons Replacement: 8 단계, 이미지 3개 중 2개 JBL Charge 4 Buttons Replacement: 8 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, pry up the button control board from the adhesive.
      • This will require cutting the adhesive surrounding the board.
      • Gently lift off the button control board feeding the ribbon cable through the slot.
      • When installing a new button control board, make sure to clean all the adhesive residue left by the old board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zachary Colwell
회원 가입일: 01/24/19
2,224 평판
안내서 5개를 작성함
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 회원
CPSU-WHITE-W19S1G1
4 회원들
안내서 64개를 작성함
2가이드 댓글
Hi - where can I buy the button control board?
Rahman Sayeed - 답글 공유
How do I boot up JBL CHARGE 4
sashajankovic527 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 31
지난 30일: 137
전체 시간: 27,118
