주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge Battery Replacement
필요한 것
    1. JBL Charge Battery Replacement, Case: 1 단계, 이미지 3개 중 1개 JBL Charge Battery Replacement, Case: 1 단계, 이미지 3개 중 2개 JBL Charge Battery Replacement, Case: 1 단계, 이미지 3개 중 3개
      • Make sure the device is powered off before you begin to disassemble the speaker.
      • Remove the trim from the speaker using a jimmy or metal spudger.
      댓글 쓰기
    2. JBL Charge Battery Replacement: 2 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
      • Remove the battery cover and set the cover aside.
      댓글 쓰기
    3. JBL Charge Battery Replacement: 3 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
      • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
      댓글 쓰기
    4. JBL Charge Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Use a spudger to lift the battery out of the device.
      • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
      • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
      댓글 쓰기
    5. JBL Charge Battery Replacement: 5 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
      댓글 쓰기
    6. JBL Charge Battery Replacement: 6 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
      • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
      댓글 쓰기
    7. JBL Charge Battery Replacement: 7 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 7 단계, 이미지 2개 중 2개
      • Once the back casing is open, disconnect the three white connectors from the motherboard.
      • Remove the upper casing.
      댓글 쓰기
    1. JBL Charge Battery Replacement, Battery: 8 단계, 이미지 1개 중 1개
      • Turn your attention to the back casing removed in Step 7.
      댓글 쓰기
    2. JBL Charge Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Using a razor blade, remove the glue holding the battery cable in place.
      • Use multiple vertical cuts to remove pieces of the glue.
      • Be careful not to cut the battery cables.
      댓글 쓰기
    3. JBL Charge Battery Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the foam surrounding the battery cable.
      댓글 쓰기
    4. JBL Charge Battery Replacement: 11 단계, 이미지 1개 중 1개
      • To remove the battery, pull the battery cable through the hole.
      • This entire white piece needs to be replaced (if replacing the aux/usb port).
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 40명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Joe Durand
회원 가입일: 04/01/15
2,313 평판
안내서 2개를 작성함
Cal Poly, Team 12-4, Lancaster Spring 2015 Cal Poly, Team 12-4, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G4
2 회원들
안내서 33개를 작성함
35가이드 댓글
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - 답글 공유
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - 답글 공유
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose - 답글 공유
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - 답글 공유
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 92
지난 30일: 429
전체 시간: 239,566
