주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Clip 3 Battery Replacement
필요한 것
    1. JBL Clip 3 Battery Replacement, Speaker Grill: 1 단계, 이미지 2개 중 1개 JBL Clip 3 Battery Replacement, Speaker Grill: 1 단계, 이미지 2개 중 2개
      • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
      • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
      댓글 쓰기
    1. JBL Clip 3 Battery Replacement, Speaker Housing: 2 단계, 이미지 2개 중 1개 JBL Clip 3 Battery Replacement, Speaker Housing: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
      댓글 쓰기
    2. JBL Clip 3 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Separate the speaker housing from the rest of the body.
      • This requires minimal force; they are not glued together.
      댓글 쓰기
    3. JBL Clip 3 Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Clip 3 Battery Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
      댓글 쓰기
    1. JBL Clip 3 Battery Replacement, Carabiner Clip: 5 단계, 이미지 2개 중 1개 JBL Clip 3 Battery Replacement, Carabiner Clip: 5 단계, 이미지 2개 중 2개
      • Lift the metal carabiner clip from the speaker housing.
      • They are not glued together and should separate easily.
      • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
      댓글 쓰기
    1. JBL Clip 3 Battery Replacement, Speaker Battery: 6 단계, 이미지 2개 중 1개 JBL Clip 3 Battery Replacement, Speaker Battery: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
      • The wires connecting to the battery are not very long, so be careful when removing them.
      댓글 쓰기
    2. JBL Clip 3 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to remove the four screws that secure the motherboard.
      댓글 쓰기
    3. JBL Clip 3 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Gently lift the motherboard away from the speaker housing.
      • Take care not to damage the soldered connections when lifting the motherboard.
      댓글 쓰기
    4. JBL Clip 3 Battery Replacement: 9 단계, 이미지 2개 중 1개 JBL Clip 3 Battery Replacement: 9 단계, 이미지 2개 중 2개
      • Use an opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
      • Avoid puncturing or bending the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
      • During reassembly, remember to superglue the new battery back into place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kyle Montague
회원 가입일: 03/28/22
265 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G5
3 회원들
안내서 16개를 작성함
3가이드 댓글
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - 답글 공유
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee - 답글 공유
Thank you - very helpful guide! Was able to replace my battery with no issues.
JB Zorg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 46
지난 30일: 173
전체 시간: 11,044
