주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Clip 4 Battery Replacement
필요한 것
    1. JBL Clip 4 Battery Replacement, Front Grill: 1 단계, 이미지 1개 중 1개
      • Get a tool to pry the front grill off, ideally using one of the iFixit tools. This is required as the front grill is glued onto the device.
      댓글 쓰기
    2. JBL Clip 4 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
      댓글 쓰기
    1. JBL Clip 4 Battery Replacement, Back Housing: 3 단계, 이미지 1개 중 1개
      • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
      댓글 쓰기
    2. JBL Clip 4 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
      댓글 쓰기
    1. JBL Clip 4 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
      댓글 쓰기
    2. JBL Clip 4 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Now all you need to do is pull the battery out of the case its in and you have successfully disconnected the battery from the device.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Trey Adao
회원 가입일: 03/06/26
598 평판
안내서 6개를 작성함
UMass Dartmouth, Team 3-4, Shaddix Spring 2026 UMass Dartmouth, Team 3-4, Shaddix Spring 2026 회원
UMASSD-SHADDIX-S26S3G4
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 51
전체 시간: 175
