주요 콘텐츠로 건너뛰기
JBL Flip 3 Battery Replacement
필요한 것
  1. JBL Flip 3 Battery Replacement, Remove the first protective cover: 1 단계, 이미지 2개 중 1개 JBL Flip 3 Battery Replacement, Remove the first protective cover: 1 단계, 이미지 2개 중 2개
    • Pry up the two tabs on one side using a spudger.
  2. JBL Flip 3 Battery Replacement: 2 단계, 이미지 2개 중 1개 JBL Flip 3 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Pry up the other two tabs, they are located on the other side.
    • Be careful not to break the buttons, as they are fragile.
  3. JBL Flip 3 Battery Replacement, Remove the first protective cover: 3 단계, 이미지 2개 중 1개 JBL Flip 3 Battery Replacement, Remove the first protective cover: 3 단계, 이미지 2개 중 2개
    • Remove the cover carefully.
    • Don't pull it too much, otherwise it could break.
  4. JBL Flip 3 Battery Replacement, Remove the second protective cover: 4 단계, 이미지 3개 중 1개 JBL Flip 3 Battery Replacement, Remove the second protective cover: 4 단계, 이미지 3개 중 2개 JBL Flip 3 Battery Replacement, Remove the second protective cover: 4 단계, 이미지 3개 중 3개
    • Unscrew the four screws located on the edge.
    • The screws usually remain in, but if they fall out, put them aside.
  5. JBL Flip 3 Battery Replacement, Remove the second protective cover: 5 단계, 이미지 1개 중 1개
    • Remove the second protective cover carefully.
결론
Repeat the same steps in reverse order to reassemble your device.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
5다른 기여자 명과 함께
Lasse.gra
회원 가입일: 12/19/17
770 평판
안내서 4개를 작성함
3가이드 댓글
What’s your problem?
Ali - 답글
Uncomplete and Sketchy!
How come is this a battery replacement guide? It is only up to the removal of the second protective layer. Many questions remain: How to locate the battery? How to unplug it? How to remove it? How to plug the new one? How to reassamble? …
Yusuf - 답글
You're right, the current version does not answer your questions. However, it seems that 5 people could still successfully repair their device with the help of that guide, so rather than taking it down, we'd suggest you and others help complete the guide by adding your pictures and information you found?
Sandra Hiller -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 104
전체 시간: 4,861
