주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Flip 4 Battery Replacement
필요한 것
    1. JBL Flip 4 Battery Replacement, Shell: 1 단계, 이미지 3개 중 1개 JBL Flip 4 Battery Replacement, Shell: 1 단계, 이미지 3개 중 2개 JBL Flip 4 Battery Replacement, Shell: 1 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
      • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
      • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
      • Watch out not to damage the clips on the buttons' side, pry open with caution.
      • Pull the cover off with your thumbs.
      댓글 쓰기
    2. JBL Flip 4 Battery Replacement: 2 단계, 이미지 3개 중 1개 JBL Flip 4 Battery Replacement: 2 단계, 이미지 3개 중 2개 JBL Flip 4 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
      • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
      • Pry away one end of the rubber spine with your thumbs and it should come off.
      • Prying off the spine may take some persuading.
      • The speakers are strong magnets. Keep it away from other sensitive electronics.
      댓글 쓰기
    1. JBL Flip 4 Battery Replacement, remove cap: 3 단계, 이미지 3개 중 1개 JBL Flip 4 Battery Replacement, remove cap: 3 단계, 이미지 3개 중 2개 JBL Flip 4 Battery Replacement, remove cap: 3 단계, 이미지 3개 중 3개
      • The end cap opposite to the USB port: Twist - or - remove screws from the cap. (depends on your model-version: only older version have 9mm Phillips #1 screws)
      • Pull the end cap off with your hands.
      댓글 쓰기
    2. JBL Flip 4 Battery Replacement: 4 단계, 이미지 3개 중 1개 JBL Flip 4 Battery Replacement: 4 단계, 이미지 3개 중 2개 JBL Flip 4 Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Remove two 11mm Phillips #1 screws on the battery cover.
      • Pull the battery cover off with your hands.
      댓글 쓰기
    3. JBL Flip 4 Battery Replacement: 5 단계, 이미지 3개 중 1개 JBL Flip 4 Battery Replacement: 5 단계, 이미지 3개 중 2개 JBL Flip 4 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the large white plug that connects the wires from the battery to the main board using your hands.
      • Pull the battery out with your hands.
      • If the battery is swollen, you might not be able to pull it out with your hands, you might just rip the cables+charging board out.
      • In this case: You can pushing out the Battery, which we documented in an extra guide.
      • A short preview: You can remove the other radiator, unscrew the charging port and gently pull it out just a bit so a pencil (flat end) can fit in and push out the battery from this side.
      • The port might be hot glued and under the tapes there are very small normal and ribbon cables, so be careful not to cut or rip them.
      • More details and pictures in the separated extra guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 199명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Philip Pang
회원 가입일: 10/08/18
1,461 평판
안내서 4개를 작성함
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 회원
CPSU-WHITE-F18S4G3
4 회원들
안내서 42개를 작성함
80가이드 댓글
Is the battery glued into the socket like the Flip 3?
Kenneth - 답글 공유
No it isn’t. but the black rubber around it makes it really hard to get out. try to push it from the otherside by removing the charging-port.
Be careful not to pierce the battery
Richardo Otros - 답글 공유
Yes with me the battery was glued
Diter Freeman - 답글 공유
Be careful and don’t do like me: my old battery was bloated, so I had to push from the other side, but when doing so, I ripped the ribbon cable from the power button… now trying to find a replacement cable
jmbarroso - 답글 공유
Did you find the cable of the power button?
mohamed da - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 58
지난 7일: 492
지난 30일: 2,114
전체 시간: 294,169
