주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Flip 4 Controls Board Replacement
필요한 것
    1. JBL Flip 4 Controls Board Replacement, Controls Board: 1 단계, 이미지 3개 중 1개 JBL Flip 4 Controls Board Replacement, Controls Board: 1 단계, 이미지 3개 중 2개 JBL Flip 4 Controls Board Replacement, Controls Board: 1 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
      • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
      • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
      • Pull off the cover off with your thumbs.
      댓글 쓰기
    2. JBL Flip 4 Controls Board Replacement: 2 단계, 이미지 3개 중 1개 JBL Flip 4 Controls Board Replacement: 2 단계, 이미지 3개 중 2개 JBL Flip 4 Controls Board Replacement: 2 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool under the clear rubber cover over the button control board.
      • Pry up the cover using the opening tool.
      • The cover is glued on so it will take some force to pry up.
      댓글 쓰기
    3. JBL Flip 4 Controls Board Replacement: 3 단계, 이미지 2개 중 1개 JBL Flip 4 Controls Board Replacement: 3 단계, 이미지 2개 중 2개
      • Pry up the button control board by inserting the metal spudger underneath both sides of the board.
      • Try not to damage the green control board while using the metal tools.
      • The control board is glued down as well, so you will need to use some force.
      댓글 쓰기
    4. JBL Flip 4 Controls Board Replacement: 4 단계, 이미지 1개 중 1개
      • Once the board is partially unattached, pull it off using your hands.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Philip Pang
회원 가입일: 10/08/18
1,461 평판
안내서 4개를 작성함
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 회원
CPSU-WHITE-F18S4G3
4 회원들
안내서 42개를 작성함
9가이드 댓글
Where can i buy ,control board for jbl flip 4?
Mihajlo - 답글 공유
I would also be interested in buying a board (but the one at the top of the speaker, whichis holding the On and Off, as well as the JBL Connect button ). Thanks!
JPA - 답글 공유
Does anyone at ifixit know where to get replacement boards?
EAN - 2/28/19
Eric - 답글 공유
Id be interested in JBLmaking a minimally acceptable product
Mary Lea McTurnan - 답글 공유
Where can I buy the ribbon cable?
Randl Manigsaca - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 46
지난 30일: 151
전체 시간: 37,460
