주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Pulse 3 Charging Port Replacement
필요한 것
    1. JBL Pulse 3 Charging Port Replacement, Speaker Grill: 1 단계, 이미지 1개 중 1개
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      댓글 쓰기
    2. JBL Pulse 3 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
      • Repeat step 1 for bottom right corner of speaker grill.
      댓글 쓰기
    3. JBL Pulse 3 Charging Port Replacement: 3 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 3 단계, 이미지 2개 중 2개
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      댓글 쓰기
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      댓글 쓰기
    1. JBL Pulse 3 Charging Port Replacement, Outside Casing: 5 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement, Outside Casing: 5 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      댓글 쓰기
    2. JBL Pulse 3 Charging Port Replacement: 6 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 6 단계, 이미지 2개 중 2개
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      댓글 쓰기
    3. JBL Pulse 3 Charging Port Replacement: 7 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      댓글 쓰기
    4. JBL Pulse 3 Charging Port Replacement: 8 단계, 이미지 1개 중 1개
      • Pull off the top disc of the JBL Pulse 3.
      댓글 쓰기
    5. JBL Pulse 3 Charging Port Replacement: 9 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      댓글 쓰기
    6. JBL Pulse 3 Charging Port Replacement: 10 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 10 단계, 이미지 2개 중 2개
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      댓글 쓰기
    7. JBL Pulse 3 Charging Port Replacement: 11 단계, 이미지 1개 중 1개
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      댓글 쓰기
    1. JBL Pulse 3 Charging Port Replacement, LED Light Display: 12 단계, 이미지 3개 중 1개 JBL Pulse 3 Charging Port Replacement, LED Light Display: 12 단계, 이미지 3개 중 2개 JBL Pulse 3 Charging Port Replacement, LED Light Display: 12 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      댓글 쓰기
    2. JBL Pulse 3 Charging Port Replacement: 13 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 13 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to pull the five connections off of the LED light display.
      댓글 쓰기
    1. JBL Pulse 3 Charging Port Replacement, Motherboard: 14 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement, Motherboard: 14 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
      댓글 쓰기
    2. JBL Pulse 3 Charging Port Replacement: 15 단계, 이미지 3개 중 1개 JBL Pulse 3 Charging Port Replacement: 15 단계, 이미지 3개 중 2개 JBL Pulse 3 Charging Port Replacement: 15 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
      댓글 쓰기
    3. JBL Pulse 3 Charging Port Replacement: 16 단계, 이미지 1개 중 1개
      • Pull the rest of the motherboard out from the LED light display.
      • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
      댓글 쓰기
    1. JBL Pulse 3 Charging Port Replacement, Speaker: 17 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement, Speaker: 17 단계, 이미지 2개 중 2개
      • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
      댓글 쓰기
    2. JBL Pulse 3 Charging Port Replacement: 18 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 18 단계, 이미지 2개 중 2개
      • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
      댓글 쓰기
    1. JBL Pulse 3 Charging Port Replacement, Charging Port: 19 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement, Charging Port: 19 단계, 이미지 2개 중 2개
      • Repeat the steps to take out all three speakers on the base of the JBL Pulse 3.
      • Using a Phillips #0 screwdriver, remove the 6 mm screw under each of the three speakers around the base of the JBL Pulse 3.
      댓글 쓰기
    2. JBL Pulse 3 Charging Port Replacement: 20 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 20 단계, 이미지 2개 중 2개
      • Grab the outside of the JBL Pulse 3 at the bottom and pull outward until the outside button cover comes off.
      댓글 쓰기
    3. JBL Pulse 3 Charging Port Replacement: 21 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 21 단계, 이미지 2개 중 2개
      • Disconnect the two connections from the inside side of the base of the JBL Pulse 3 by pushing on the wire with your index finger in the opposite direction of the connection.
      댓글 쓰기
    4. JBL Pulse 3 Charging Port Replacement: 22 단계, 이미지 2개 중 1개 JBL Pulse 3 Charging Port Replacement: 22 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the four 10mm screws by the push buttons on the side of the base of the JBL Pulse 3.
      댓글 쓰기
    5. JBL Pulse 3 Charging Port Replacement: 23 단계, 이미지 1개 중 1개
      • Pull off the inside button cover with the attached charging port. The charging port should now be removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kaitlyn Greenfield
회원 가입일: 09/20/18
1,188 평판
안내서 6개를 작성함
5가이드 댓글
And how to put it back with cut cable?
Robert Rpunkt - 답글 공유
Good very good
Shadow Takeshi - 답글 공유
I've done a teardown and was able to access the charging terminal without cutting any wires. I didn't have a replacement, so I just put it back together hoping that cleaning it would work. Didn't work.
Beresford Crowder - 답글 공유
Yeah its obvious they need to use a C type port they aren't as easy to tear up
Lloyd Mars - 답글 공유
You do not have to tear it completely down unless I have a newer version after you take the speaker grill out from around the unit the thin black skeleton like gram that stiffened the grill will actually unclip from the unit with a hook tool or a ice pick that's been heated up and put a slight bend in it take your time because you can break the frame but even if you do its what they make jb weld and gorilla glue for I broke mine but went back together fine after letting the glue set up sprinkled some baking soda on it and made it twice as strong you've only got 4 screws this way cause they well the replacement plug for around $12 don't know why they don't go ahead and use the C type port smh when these came out they was already selling the replacement plug lol
Lloyd Mars - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 55
지난 30일: 150
전체 시간: 19,695
