주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Pulse 3 LED Light Display Replacement
필요한 것
    1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: 1 단계, 이미지 1개 중 1개
      • Lay the JBL Pulse 3 on its side as shown in the picture.
      • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
      댓글 쓰기
    2. JBL Pulse 3 LED Light Display Replacement: 2 단계, 이미지 1개 중 1개
      • Repeat step 1 for bottom right corner of speaker grill.
      댓글 쓰기
    3. JBL Pulse 3 LED Light Display Replacement: 3 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement: 3 단계, 이미지 2개 중 2개
      • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
      • Lift and pull straight out to pull grill off the posts.
      댓글 쓰기
      • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
      댓글 쓰기
    1. JBL Pulse 3 LED Light Display Replacement, Outside Casing: 5 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement, Outside Casing: 5 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
      댓글 쓰기
    2. JBL Pulse 3 LED Light Display Replacement: 6 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement: 6 단계, 이미지 2개 중 2개
      • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
      댓글 쓰기
    3. JBL Pulse 3 LED Light Display Replacement: 7 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
      댓글 쓰기
    4. JBL Pulse 3 LED Light Display Replacement: 8 단계, 이미지 1개 중 1개
      • Pull off the top disc of the JBL Pulse 3.
      댓글 쓰기
    5. JBL Pulse 3 LED Light Display Replacement: 9 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
      댓글 쓰기
    6. JBL Pulse 3 LED Light Display Replacement: 10 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement: 10 단계, 이미지 2개 중 2개
      • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
      댓글 쓰기
    7. JBL Pulse 3 LED Light Display Replacement: 11 단계, 이미지 1개 중 1개
      • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
      댓글 쓰기
    1. JBL Pulse 3 LED Light Display Replacement, LED Light Display: 12 단계, 이미지 3개 중 1개 JBL Pulse 3 LED Light Display Replacement, LED Light Display: 12 단계, 이미지 3개 중 2개 JBL Pulse 3 LED Light Display Replacement, LED Light Display: 12 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
      • Pull the LED light display off of the JBL Pulse 3 base.
      댓글 쓰기
    2. JBL Pulse 3 LED Light Display Replacement: 13 단계, 이미지 2개 중 1개 JBL Pulse 3 LED Light Display Replacement: 13 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to pull the five connections off of the LED light display.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kaitlyn Greenfield
회원 가입일: 09/20/18
1,188 평판
안내서 6개를 작성함
4가이드 댓글
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - 답글 공유
Wow jbl
Gyyzhuahyz8yus
Majd Tom - 답글 공유
Where to buy the leds?
mj.viana1993 - 답글 공유
Hello i need an assitance in a LED screen manufacturing
volkanoo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 48
전체 시간: 4,269
