주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Pulse Motherboard Replacement
필요한 것
  1. JBL Pulse Motherboard Replacement, Button Board: 1 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
    댓글 쓰기
  2. JBL Pulse Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    댓글 쓰기
  3. JBL Pulse Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
    댓글 쓰기
  4. JBL Pulse Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the button board, exposing the attached cable.
    댓글 쓰기
  5. JBL Pulse Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    댓글 쓰기
  6. JBL Pulse Motherboard Replacement, Outer Casing: 6 단계, 이미지 3개 중 1개 JBL Pulse Motherboard Replacement, Outer Casing: 6 단계, 이미지 3개 중 2개 JBL Pulse Motherboard Replacement, Outer Casing: 6 단계, 이미지 3개 중 3개
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
    댓글 쓰기
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: 7 단계, 이미지 2개 중 1개 JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: 7 단계, 이미지 2개 중 2개
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
    댓글 쓰기
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: 8 단계, 이미지 1개 중 1개
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
    댓글 쓰기
  9. JBL Pulse Motherboard Replacement: 9 단계, 이미지 3개 중 1개 JBL Pulse Motherboard Replacement: 9 단계, 이미지 3개 중 2개 JBL Pulse Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
    댓글 쓰기
  10. JBL Pulse Motherboard Replacement: 10 단계, 이미지 2개 중 1개 JBL Pulse Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove cables by pulling firmly.
    댓글 쓰기
  11. JBL Pulse Motherboard Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    • Once all of the cables are removed, grip the motherboard and slide it out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Maxwell Busenbarrick
회원 가입일: 09/15/16
1,401 평판
안내서 7개를 작성함
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G6
3 회원들
안내서 20개를 작성함
3가이드 댓글
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - 답글 공유
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - 답글 공유
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 55
전체 시간: 10,217
