주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Pulse Speakers Replacement
필요한 것
    1. JBL Pulse Speakers Replacement, Button Board: 1 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to pry around the edges of the circular rubber panel.
      댓글 쓰기
    2. JBL Pulse Speakers Replacement: 2 단계, 이미지 1개 중 1개
      • Once the edges are loose, pull off the rubber button panel completely.
      • New adhesive will have to be applied when reassembling.
      댓글 쓰기
    3. JBL Pulse Speakers Replacement: 3 단계, 이미지 1개 중 1개
      • Use your plastic opening tool to pry the button board loose by lifting the edges.
      댓글 쓰기
    4. JBL Pulse Speakers Replacement: 4 단계, 이미지 1개 중 1개
      • Lift the button board, exposing the attached cable.
      댓글 쓰기
    5. JBL Pulse Speakers Replacement: 5 단계, 이미지 1개 중 1개
      • Pull black piece on top of socket away from board to loosen, then detach the cable.
      댓글 쓰기
    1. JBL Pulse Speakers Replacement, Outer Casing: 6 단계, 이미지 3개 중 1개 JBL Pulse Speakers Replacement, Outer Casing: 6 단계, 이미지 3개 중 2개 JBL Pulse Speakers Replacement, Outer Casing: 6 단계, 이미지 3개 중 3개
      • Take out the four 9mm black PH0 screws from the top and bottom of the device.
      • Pull off cap by hand.
      • The outer casing can now be removed.
      댓글 쓰기
    1. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: 7 단계, 이미지 2개 중 1개 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: 7 단계, 이미지 2개 중 2개
      • Remove the tape around the cables on the top of the device.
      • Remove the cables by lifting up on the black bracket and then pulling the cable out.
      댓글 쓰기
    1. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: 8 단계, 이미지 1개 중 1개
      • Remove two black 9mm PH0 screws from outside of inner casing on each side.
      댓글 쓰기
    2. JBL Pulse Speakers Replacement: 9 단계, 이미지 3개 중 1개 JBL Pulse Speakers Replacement: 9 단계, 이미지 3개 중 2개 JBL Pulse Speakers Replacement: 9 단계, 이미지 3개 중 3개
      • Use your metal spudger to unhook the bracket holding the case together.
      • Pull apart the casing with your hands.
      댓글 쓰기
    3. JBL Pulse Speakers Replacement: 10 단계, 이미지 2개 중 1개 JBL Pulse Speakers Replacement: 10 단계, 이미지 2개 중 2개
      • Remove cables by pulling firmly.
      댓글 쓰기
    1. JBL Pulse Speakers Replacement, Speakers: 11 단계, 이미지 2개 중 1개 JBL Pulse Speakers Replacement, Speakers: 11 단계, 이미지 2개 중 2개
      • Remove four black PH0 9mm screws.
      • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
      • New speakers will have to be re-soldered to these wires.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Maxwell Busenbarrick
회원 가입일: 09/15/16
1,401 평판
안내서 7개를 작성함
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G6
3 회원들
안내서 49개를 작성함
9가이드 댓글
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - 답글 공유
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - 답글 공유
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
Vishakh A V - 답글 공유
what is the speaker specification that I can buy for replacement?
rbalagr - 답글 공유
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 64
전체 시간: 8,478
