주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Wave Beam Case Disassembly
필요한 것
    1. JBL Wave Beam Case Disassembly, Heat up the case: 1 단계, 이미지 1개 중 1개
      • Open up your case and remove the earbuds. Prepare a heat gun at around 150℃, and gently heat up the front part of the case, around where the LED is.
      댓글 쓰기
    2. JBL Wave Beam Case Disassembly, Insert a plastic pick: 2 단계, 이미지 2개 중 1개 JBL Wave Beam Case Disassembly, Insert a plastic pick: 2 단계, 이미지 2개 중 2개
      • Now try to insert an opening pick into the seam as shown. If you can't get it in, try heating the case more or using a different pick.
      • Slide the pick around the edge of the case until it reaches the back, next to the hinge part. You can apply more heat here if this is too difficult.
      • Repeat with a second opening pick, going round the other side. The second image shows what your case should now look like.
      댓글 쓰기
    3. JBL Wave Beam Case Disassembly, Lift out the internals: 3 단계, 이미지 1개 중 1개
      • Use a plastic tool to lift up the internals as shown
      • If this is too difficult, you might want to use a third pick, and pry around the area under the LED.
      댓글 쓰기
    4. JBL Wave Beam Case Disassembly, Remove the electronics: 4 단계, 이미지 2개 중 1개 JBL Wave Beam Case Disassembly, Remove the electronics: 4 단계, 이미지 2개 중 2개
      • You should now have removed the outer case. Remove the two Phillips #0 screws next to the exposed USB port.
      • Pull the motherboard directly upwards. Be gentle here, as it is still connected to the glued-down battery
      • Use a plastic tool to pry out the battery, it is attached to the case with a sticky pad. If you have isopropyl alcohol, apply some underneath the battery to loosen the adhesive.
      댓글 쓰기
    5. JBL Wave Beam Case Disassembly, Desolder the battery: 5 단계, 이미지 1개 중 1개
      • The battery is connected to the motherboard with either 3 or 2 solder pads. Use a soldering iron and flux to remove all of them, being careful not to cause any shorts.
      댓글 쓰기
      • Solder the black and red wires of your new battery to GND and BATT on the motherboard, respectively. If there is a third wire (temperature sensor) solder it to the NTC pad.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chris P. Croutonne
회원 가입일: 07/19/25
1,208 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 113
지난 30일: 416
전체 시간: 2,865
