주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JD Razor 2000 Fastening Button on Handle Bar Replacement
필요한 것
    1. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: 1 단계, 이미지 3개 중 1개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: 1 단계, 이미지 3개 중 2개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the String: 1 단계, 이미지 3개 중 3개
      • Firmly hold the handle bar in place.
      • Grab with one hand the black removable tip of the handle bar and pull it out.
      • Pull out the end of the tied string through the removable tip.
      댓글 쓰기
    2. JD Razor 2000 Fastening Button on Handle Bar Replacement, Untying the Knot: 2 단계, 이미지 2개 중 1개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Untying the Knot: 2 단계, 이미지 2개 중 2개
      • Untie the knot at the end of the string.
      • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
      댓글 쓰기
    3. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the Handlebar: 3 단계, 이미지 2개 중 1개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling Out the Handlebar: 3 단계, 이미지 2개 중 2개
      • Press down firmly on the golden fastening button located on the handle bar being replaced.
      • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
      • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
      댓글 쓰기
    1. JD Razor 2000 Fastening Button on Handle Bar Replacement, Depressing the Button: 4 단계, 이미지 2개 중 1개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Depressing the Button: 4 단계, 이미지 2개 중 2개
      • Press strongly down on the golden fastening button located on the loose handle bar.
      댓글 쓰기
    2. JD Razor 2000 Fastening Button on Handle Bar Replacement, Grasping the Button: 5 단계, 이미지 2개 중 1개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Grasping the Button: 5 단계, 이미지 2개 중 2개
      • Tilt the opening of the handle towards you.
      • Reach in carefully with the small needle-nose pliers and firmly grab the golden fastening button.
      댓글 쓰기
    3. JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling out the Button: 6 단계, 이미지 2개 중 1개 JD Razor 2000 Fastening Button on Handle Bar Replacement, Pulling out the Button: 6 단계, 이미지 2개 중 2개
      • Once grasping the golden fastening button tightly with small needle-nosed pliers, carefully and slowly pull it out of the handle bar.
      • Do not pull out the fastening button rapidly. This may result in the button shooting across the room with great speed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin Church
회원 가입일: 10/16/14
297 평판
안내서 2개를 작성함
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G46
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 23
전체 시간: 1,097
