주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JYX-S55 Battery Replacement
필요한 것
  1. JYX-S55 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
    댓글 쓰기
  2. JYX-S55 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
    댓글 쓰기
  3. JYX-S55 Battery Replacement: 3 단계, 이미지 2개 중 1개 JYX-S55 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
    댓글 쓰기
  4. JYX-S55 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use a nylon spudger to pry the battery free from the glue.
    • It is important to note do NOT use heat or sharp objects, as the lithium-ion battery is flammable and could potentially explode.
    댓글 쓰기
  5. JYX-S55 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the red and black wires from the battery.
    • Remove the battery from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sarah Iceman
회원 가입일: 02/24/23
502 평판
안내서 2개를 작성함
Marist, Team 1-5, Chaterdon Spring 2023 Marist, Team 1-5, Chaterdon Spring 2023 회원
MARS-CHATERDON-S23S1G5
3 회원들
안내서 8개를 작성함
3가이드 댓글
Hi, thanks for the pictures that really helped. What type of battery is needed? Can you email me at vrhaiza@gmail.com.
Rhaiza Villafranca - 답글 공유
Can you please advise what type of battery would be needed? What if I don't have a nylon spudger? What can I use in exchange?
Jasmine - 답글 공유
I opened the Karaoke machine:
Lithium-ion
Type- Lithium-ion Battery
Capacity: 3.7V/5200mAh
Model:18650C
Charging limited:4.2V
Date: 2022L1
M
DeniseCabral - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 29
지난 30일: 171
전체 시간: 8,245
