주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jawbone MINI JAMBOX Side Button Assembly Replacement
필요한 것
    1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: 1 단계, 이미지 2개 중 1개 Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: 1 단계, 이미지 2개 중 2개
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      댓글 쓰기
    2. Jawbone MINI JAMBOX Side Button Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      댓글 쓰기
    3. Jawbone MINI JAMBOX Side Button Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Slide out the rubber foot located on the bottom of the case.
      댓글 쓰기
    4. Jawbone MINI JAMBOX Side Button Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      댓글 쓰기
    5. Jawbone MINI JAMBOX Side Button Assembly Replacement: 5 단계, 이미지 3개 중 1개 Jawbone MINI JAMBOX Side Button Assembly Replacement: 5 단계, 이미지 3개 중 2개 Jawbone MINI JAMBOX Side Button Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      댓글 쓰기
    1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: 6 단계, 이미지 2개 중 1개 Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: 6 단계, 이미지 2개 중 2개
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      댓글 쓰기
    2. Jawbone MINI JAMBOX Side Button Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Using the standard metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      댓글 쓰기
    3. Jawbone MINI JAMBOX Side Button Assembly Replacement: 8 단계, 이미지 3개 중 1개 Jawbone MINI JAMBOX Side Button Assembly Replacement: 8 단계, 이미지 3개 중 2개 Jawbone MINI JAMBOX Side Button Assembly Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF or "zero insertion force" ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      댓글 쓰기
    4. Jawbone MINI JAMBOX Side Button Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Using the spudger, push the button in and create a small gap between the outside structure and the button.
      댓글 쓰기
    5. Jawbone MINI JAMBOX Side Button Assembly Replacement: 10 단계, 이미지 1개 중 1개
      • Using a computer duster, blow any contaminants out from the button junction.
      • Using a q-tip and cleaner, wipe off any stickiness from the buttons, ensuring to prevent excessive moisture.
      • Alternate Reassembly required, read on.
      댓글 쓰기
결론
To reassemble your device, follow steps 1 through 5 in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Liam McDonnell
회원 가입일: 04/01/15
559 평판
안내서 3개를 작성함
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G1
5 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 34
전체 시간: 1,213
