주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jazz HDV178 Camcorder Operating Buttons Replacement
필요한 것
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
      • Press down on the grooved plastic with your thumbs.
      • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
      댓글 쓰기
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Battery: 2 단계, 이미지 1개 중 1개
      • Once you have the back cover off, the camcorder should look like this.
      • Look on the battery for a model number to assure that you acquire the correct replacement part.
      • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
      댓글 쓰기
    2. Jazz HDV178 Camcorder Operating Buttons Replacement: 3 단계, 이미지 1개 중 1개
      • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
      댓글 쓰기
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Housing: 4 단계, 이미지 1개 중 1개
      • Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
      • This is the bottom of the camcorder near where the wrist strap connects.
      댓글 쓰기
    2. Jazz HDV178 Camcorder Operating Buttons Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the 4.5 mm screw located near the battery slot.
      댓글 쓰기
    3. Jazz HDV178 Camcorder Operating Buttons Replacement: 6 단계, 이미지 1개 중 1개
      • Break the glue that attaches the lens cover to the camcorder by sliding the plastic prying tool beneath the circumference of the part.
      • After the glue is broken, remove the lens cover.
      댓글 쓰기
    4. Jazz HDV178 Camcorder Operating Buttons Replacement: 7 단계, 이미지 1개 중 1개
      • Use a small plastic pry tool to gently pry off the silver strip on the top of the camera.
      • Make sure to run the tool under the outline of the strip as you pry it off so the plastic does not snap.
      댓글 쓰기
    5. Jazz HDV178 Camcorder Operating Buttons Replacement: 8 단계, 이미지 3개 중 1개 Jazz HDV178 Camcorder Operating Buttons Replacement: 8 단계, 이미지 3개 중 2개 Jazz HDV178 Camcorder Operating Buttons Replacement: 8 단계, 이미지 3개 중 3개
      • Locate the side of the camcorder beneath the lens and on the opposite side of the wrist strap.
      • Remove the silver strip using the same process as the previous step.
      • Remove the two 4 mm screws that were hidden under the cover.
      댓글 쓰기
    6. Jazz HDV178 Camcorder Operating Buttons Replacement: 9 단계, 이미지 3개 중 1개 Jazz HDV178 Camcorder Operating Buttons Replacement: 9 단계, 이미지 3개 중 2개 Jazz HDV178 Camcorder Operating Buttons Replacement: 9 단계, 이미지 3개 중 3개
      • Pry off the rubbery cap, which covers the buttons. Use the same process as the previous two steps.
      • Slide your prying tool underneath the entire cover to ensure that the glue breaks cleanly and the cover does not snap.
      댓글 쓰기
    7. Jazz HDV178 Camcorder Operating Buttons Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the three combined buttons so they are not misplaced.
      댓글 쓰기
    8. Jazz HDV178 Camcorder Operating Buttons Replacement: 11 단계, 이미지 2개 중 1개 Jazz HDV178 Camcorder Operating Buttons Replacement: 11 단계, 이미지 2개 중 2개
      • Using a firm hold on both sides of the camcorder, gently pull apart the two halves. Pressure should be evenly distributed across the entire device.
      • If the camcorder does not come apart easily, double check that all of the screws are removed. Return to the previous steps for screw removal if you find a screw that is still attached.
      댓글 쓰기
    1. Jazz HDV178 Camcorder Operating Buttons Replacement, Operating Buttons: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to remove the rubber button assembly.
      • Blow on the sensors underneath to remove any dust on the sensors.
      • You can also dab a little rubbing alcohol on the sensor pad with a Q-tip and let it dry.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Jake Devincenzi
회원 가입일: 01/28/11
170 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 24
전체 시간: 3,018
