주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
K. Preflight Checklist-Motion
  1. K. Preflight Checklist-Motion, Homing X&Y: 1 단계, 이미지 2개 중 1개 K. Preflight Checklist-Motion, Homing X&Y: 1 단계, 이미지 2개 중 2개
    • Press Home X. The hot end should move to the left towards the end stop. It will bump the end stop move to the right a few mm, than back left to the end stop and stop.
    • Measure the distance from the edge of the Top X Mount to the edge of the bearing block. Jog the hot end +10mm and re-measure. It should be 10mm larger.
    • Press Home Y. The hot end should move to the back towards the end stop. It will bump the end stop move to forward a few mm, than to the back to the end stop and stop.
    • Measure the distance from the edge of the rear corner to the edge of the bearing block. Jog the hot end -10mm and re-measure. It should be 10mm larger.
    댓글 쓰기
  2. K. Preflight Checklist-Motion, Homing Z: 2 단계, 이미지 2개 중 1개 K. Preflight Checklist-Motion, Homing Z: 2 단계, 이미지 2개 중 2개
    • During bed leveling, you want the probe position to be at the center of the bed, not the nozzle. Once you have your X and Y coordinates calculated press Home Z
    • The probe(not the nozzle) will move to the center of the bed, Deploy the probe, raise the bed, stop once the probe is triggered, and lower the bed.
    • If your probe is slightly off center we need to correct it. Manually jog the hotend so the probe is in the center of the bed. Note the coordinates
    • Take the coordinates off the web page and replace them in homez.g and homeall.g
    • G1 X178.75 Y155.2 F10000 ; go to first probe point
    댓글 쓰기
  3. K. Preflight Checklist-Motion, Motion: 3 단계, 이미지 1개 중 1개
    • Manually jog the hot end
    • When you jog +X it will move to the right
    • When you jog +Y it will move towards the back.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Husolo
회원 가입일: 06/16/21
9,382 평판
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 26
전체 시간: 1,383
